Bubbles in Paint at Door Hinges
23xr392
Brandon
Ks
2023 392 XR
The latest revisions of the hinges have a zinc shim, not a gasket.
1 (AR) 68302124AF Hinge, Upper Door, Right Side (One Upper Hinge Needed Per Door)
1 (AR) 68302125AF Hinge, Upper Door, Left Side (One Upper Hinge Needed Per Door)
1 (AR) 68297680AF Hinge, Lower Door, Right Side (One Lower Hinge Needed Per Door)
1 (AR) 68297681AF Hinge, Lower Door, Left Side (One Lower Hinge Needed Per Door)
2 (AR) 68281884AD Hinge, Hood
2 (AR) 68282145AC Hinge, Swing Gate
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
Sadly, it appears that they are not installing these hinges on new products.
NeilP
Neil
South Dakota
2024 Jeep Wrangler Sahara Unlimited
RETIRED!
Has anyone heard any more, or seen any new info about them replacing the hood, doors & tailgate vs repairing them? Someone alluded to that a few days ago but I can't find anything. I'm going in for repairs in May & would prefer new parts vs risking the chance of more corrosion showing up on the repaired parts.
brewtus98
Bryan
Toledo, Ohio
2018 Sahara, 2003 TJ, 2004 TJ Rubicon, 2004 LJ
Well heck, that only took 5 years for them to figure out a band-aid
So what about all the fixes out there that didn't get this "improved" symptom treatment?
Still need to fix the cause and fully paint from factory the area - sealing all bare metal and fix the contamination issues causing bubbles away from hinges on edges of panels!!
RAO
Ray
NC
2015 JKU Sahara; 2022 JL Rubicon; 2025 Sahara
Are these available separately? Part numbers? I know it says to do only affected hinges but maybe good preventive maintenance to install them BEFORE there is an issue?
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
If it really is a sacrificial anode (which it is), you would think they will have to make replacements available eventually.
dogbreath650
Bobo
06 LJ Rubicon
I wonder if the shim itself is replaceable like most sacrificial anodes or if we would have to replace the entire assy once the shim gets eaten up?
rayzjeep
Ray
Melbourne, FL
2019 Jeep Wrangler Rubicon Unlimited
Aerospace Engineer
I'm waiting until all the hinges are bubbling as they only replace the bad ones...also noticing the same bubbling on the hood edge btw...
NeilP
Neil
South Dakota
RETIRED!
I just stopped at the body shop and asked them to order all of the hinges in the new TSB. I don't want mismatched hinges and I'll happily pay for the ones that weren't on the estimate.
LCW
Twin Cities MN
'19 4R TRD (gone '22 JLUR) (gone '23 Bronco BL 2d)
I think I see a gap already on my '22 hinges, but it's probably just wishful thinking. I doubt the fix was figured out a year ago (built Jan '22).
But check out the fine print... Why not do all and be done with it. Kinda BS.
Jeep Wrangler JL Bubbles in Paint at Door Hinges jeep hinge ts
72Blazer
The Real South Texas
72BlazerCrawler 72Blazer12V 88SBDuramax 18JLUR
SLP
I previously went thru this thread but can’t remember if there is a specific TSB that reads 5 year/ unlimited mileage. I know I read one saying 5 year/ 100k but vaguely remember members posting that it was unlimited. If so does anyone have an image of it? Took it to my dealer that has usually taken care of me, body shop manager came to look at it, checked the mileage (109k) and basically said you’re shit out of luck. Shook my hand and walked off.
