Best shocks?
Old Jeeper
Don
US Army Infantry, IT Engineer
I simply do not trust the rancho ones, I keep hearing so many mixed opinions about them. I have been driving on these fox 2.5s since I got the vehicle and I trust them... I'd consider falcon, king, bilstein, or another reputable brand but I do not believe rancho is reputable, there has to be some reason they are that cheap.
Lets see been running them on all my cars and trucks for over 20 years and never had an issue. For almost 10 of those years I had a Jeep offorad shop and installed then and many many Jeeps, ever had a compliant from anyone.
My Fox Rubicon Recon, at 25k miles I took them off and THREW them away, The ride could not have been any harsher. I even dropped my psi on my tires down to 22 psi trying to get a decent ride on city streets. Replaced with Rancho and the ride was GREAT. What I find interesting is that in my years of driving, only one set of shocks has ever failed and needed replacing... FOX, NOT saying they are a bad shock, I don't in judging all on 1 failure.
Again, your choice, your rig fo for it, I will reach for my Ranchos...
Old Jeeper
Don
We have 6 JLURs that run Rancho lifts with more that 250,000 combined miles. We all wheel a lot. Like a whole lot. Zero issues. We all run the 9000xl. They are great shocks and they are worth more than they charge for them.
I have wheeled 55 badge trails all over the US and approx 50 or so trails in Moab. The Jeep has been in 40+ states and towed a camper 48,000+ miles. It is a wheeling traveling Jeep.
X 2 on wheeling and miles and Ranchos have never let me down.
A Rancho story;; Bought a set of Currie Anti Rocks on my first trip with them to Maob one fasiled, it broke in two.
Wheeled without and it was fine. Came time to come home and I had an 8-10 hr drive ahead of me. Pull out of the motel and hit the highway...OMG front end of jeep dancing like a White Booted GoGo Dancer in the cage at the Whiskey A G0-G0.
Had my Rancho RS 9000XL adjustable and put the setting knob on 9 and 7 in the rear of the Jeep. WOW, the front end was way to stiff, so backed off to 8 and dialed it in and drove the next 8+ hrs at 70 mph solid as a rock...Thanks Rancho!
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
My question is why do you believe that your shocks are going bad?
Front/rear dive a lot more now as compared to when I first got the shocks during acceleration/braking + I hear it is recommended you switch them out at around 50k miles
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
interesting... so much love here for the RS9000XLs, i have fox 2.0s which i like MUCH better than the falcons i originally had, but since i run close to max gvw i get quite a bit of roll with them
Funny, thing about the Falcons. One of my buds run them. We were wheeling in Moab and he was constantly falling behind. I am like what's up? He is like this dam Jeep is throwing me around, I have to go slower as it is beating the fuck out of me. After a couple days of wheeling, his back and shoulder was in such bad shape, he went to a local chiropractor to get adjusted.
Mikester86
Michigan wishing I was on a trail...
2022 JLR
Jeep Wrangler JL Best shocks? 1668513126967
RanchoShocks
CA
www.gorancho.com
2013 JKU
We make longer travel ones too ;)
Also the shock design is different as well.
Travel is terrible with Rancho shocks.
Front ShockCompressedExtendedTravel
Rancho RS9000XL for 2" lift18.16"25.21"7.05"
Mopar 2" lift shocks (what the OP has)17.5"26.25"8.75"
Stock Rubicon with 2" shock extensions17.75"25.63"7.88"
AnnDee4444
'18 JLR 2.0
Fair enough. The RS77065 appears to be the only 2" bump stop compatible shock with more travel than the Mopar. It's travel is 0.48" more however since anything less than 18.25" of compressed length is wasted the real increase in travel is 0.41", for a total usable travel of 8.41" vs. the Mopar's 8.0".
For comparison the cheapest Fox shock has about 10.15" of usable travel on a JL with 2" bump stops (and would require an aftermarket front driveshaft). After wasting 1.18" of stroke the cheapest Bilstein has a usable travel of 8.63" (it really should be paired with 1" bump stops). Metalcloak's RockSport shocks have 11.75" of usable travel.
BTW: You really should be recommending these by increased bump stop height instead of "Vehicle Height" and "Standard Qualifier".
RanchoShocks
CA
www.gorancho.com
2013 JKU
So most folks go off "suspension height" we find. I can't recall the last time I was asked "I am using a X amount bump stop, what do you suggest?" This is from folks and shops I work with daily. (Now watch me get a ton of questions LOL)
We offer LONGER shocks too, that require a new drive shaft as well. ;)
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
Convince me to buy ranchos over the fox 2.5s I’m replacing
jhackathorne
Denver
'21 JLUR
Anything longer than the RS999068? The site says they are 29.74" extended and 20.44" collapsed for total travel of 9.3". I'm running Fox IFP 2.0 3.5-4" and they have a total travel of 11.62". And I am running a Synergy 2" lift and 2" of bumpstops.
RanchoShocks
CA
www.gorancho.com
2013 JKU
This has very close to the travel as what you have now.
https://www.gorancho.com/products/s...ho-rs7mt-monotube-shock-absorber-rs77068.html
The reason the RS999068 has less is by the design of the shock, a triple tube vs a monotube
Roky
Roky
I think your 11.6 is the rear shocks, and I think rancho is listing front shocks. So it’s a little closer, unless Rancho is listing rears as well……your fronts are 10.6……..
jhackathorne
Denver
'21 JLUR
Ah gotcha, thanks. I should’ve checked the front as well. I appreciate your response.
RanchoShocks
CA
www.gorancho.com
2013 JKU
From my end I was cross referencing the part number in the RS9000XL flavor to the RS7MT flavor.
This is a rear as you mentioned :)
