Aluminum knuckle failure
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
The cimpled Jeeps in both of these videos seem to have the same witness marks in the tapered lower ball joint bores of the knuckles. My guess is that both Jeeps had loose ball joint studs that allowed the bores to get wallowed out. That movement allowed a slide hammering affect, that when coupled to the shock load of wheel slip and ujoint crow hopping, amplified the stress leading to the compound break.
Reids high strength nodular iron knuckles and RCV axle shafts would avoid all that fun.
Thanks Mike for being such a good salesman. Now i need RCV axle shafts.
Hogdreamer
Minnesota
2019 Cherokee, 2021 Sahara Altitude
Yeah, this kinda confuses me as well. Dude is new to wheeling, yet is almost out of room on his fender for any more Badge of Honor badges.
Maybe he purchased the Rubicon used, with the badges already in place on the Jeep?
Or maybe it was a buddies Jeep he borrowed for the day?
Rangemaster
Nevada
Business Owner
Don't forget the Dynatrac HD ball joints... you know, while you're in there.
Already have the dynatrac ball joints, apex 2.5 tie rods, knuckles are on order.
Rangemaster
Nevada
Business Owner
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
Retired LEO
When I ordered my RCV axles in Feb, they said 12 weeks out for delivery. That will put me around May when I tear it all apart. I went with the FAD two piece version. I’m not sure if the one piece has a quicker delivery.
Rangemaster
Nevada
Business Owner
Dam, that is a long time. But on the otherside, had the ball joints and tierods for about 12 weeks now. Whats another 3 months.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
What's your caster angle set at? I'm not going off topic, just approaching from a different direction.
Baba Yaga
NJ
www.youtube.com
Retired LEO
Mike, No idea, never measured. I'm still running the control arms from the Mopar lift. (No caster adjustability) I never had vibrations coming from my driveshafts. I like the option of the FAD. RCVs are much stronger over stock, and the difference between the two piece and one piece is marginal. I may get adjustable arms in the future.
Baba Yaga
NJ
www.youtube.com
Retired LEO
Dont forget tube seals....LOL
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
I thought the diesels had the same cast iron knuckles as the gladiators. Was that updated somewhere mid stream or am I mistaken?
Only the Mohave gets the cast iron ones in Gladiator family.
Headbarcode
LI, New York
That's more or less what I was getting at. The 1-piece is only about 5% stronger than the 2-piece that is twice as strong as oem and I believe 19% stronger than the ujoint shafts in a 60 series axle. For such a marginal increase in strength, it's a good idea to avoid using the 1-piece on a jeep with higher than factory spec caster. The flipside to improved handling with higher caster, is the resulting negative pinion angle. This could lead to vibrations at highway speed if the driveshaft is always spinning, especially when paired with a lifted Jeep and it's higher driveshaft angle. The only real weakness from the FAD is it's window in the axle tube.
Baba Yaga
NJ
www.youtube.com
Retired LEO
Only the Mohave gets the steel ones in Gladiator family.
The Mojave knuckles are the alternative to the Reid knuckles if you dont like the orange color. LOL
