2.0 coolant top off frequency
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
These are the 2 torx bolts you need to check to make sure your water pump inlet is properly fastened. This seem to affect quite a few 2.0s
With mine, I never used thread locker or even changed out the gasket. I also never torqued them. I cranked down on them and called it a day. So far, it's still tight and no leaks. One thing I did notice when I pressure tested it, it sprayed coolant on the ground and into the radiator. So the coolant smell took a while to go away (when it happened to me it was really cold out and I was not going to rinse the whole thing off).
For anyone wanting to look, just lay on the ground and scoot yourself right under the FL part of the Jeep (about under the steering box). Look up and you'll see the lower radiator hose and where it goes to the water pump. It'll leak where the aluminum housing bolts to the water pump. If leaking, there will be pink crusty stuff all around it.
AndrewHW
Andrew
Riverside, California
2021 Jeep JLUR
21 JLUR. 12k miles. Rear coolant reservoir stick is bone dry. Front reservoir shows just below full. Odd. You shouldn’t have to worry about coolant on a less than year old vehicle. Ordered some coolant off Amazon. Will be here tomorrow.
Jank4AU
Alabama
2021 Rubicon 4xe
After checking my '21 JLUR 4xe with 8,124 miles, both reservoirs are full. Either everything was tightened to spec or maybe because many of the miles are on electric the coolant hasn't had to work that hard. Either way I'll be sure to keep an eye on it.
eugeeezy
2021 JLR
My 21 JLR was the same. Topped it off on Friday before a long drive this past weekend.
What has me concerned now is that I took the Jeep in for an oil change today and the dealer said they topped off the coolant. I will probably have to mention the TSB to them.
Jhawth
Jake
Minnesota
2021 JLUR
Glad I saw this, checked mine and it was low. Picked up some coolant and going to check the torque on those two torx bolts.
silverheep
Fort Collins, CO
2021 JLUR4xe
Just checked mine, 2020 2.0 19k miles both full. I even have an appointment next week at the dealership to have the lower hose replaced. I think the clamp isn’t on properly and it has a tiny bit of coolant build up on it. Might as well since it’s under warranty. Plus I have a big road trip next week.
@NyRey87 is this what your lower hose looked like?
Jeep Wrangler JL 2.0 coolant top off frequency A261F074-5EBB-49A0-A62B-88612FDECD33
Jeep Wrangler JL 2.0 coolant top off frequency 63E01D06-2E17-4296-916E-3A9AD3E3E00B
  • Like
Reactions: J0E
jjvincent
Bethlehem, PA
Mechanical Engineer
Just to make everyone feel better, after cranking down on those bolts a while back, no coolant leaks. While checking my work, seen that the oil water heat exchanger was leaking oil. No suprise to me, two of the bolts were loose. Got to love Jeep quality.
  • Like
Reactions: J0E
JimmyB
Berks County - PA
2021 Rubicon
Had the same problem with my wife's Jeep today. Jeep overheated on her way to her patient's house 30seconds before she got there. Coolant smell according to her. I got there and there was a pool of coolant under the front of the Jeep. Both bolts were loose enough that I got a full turn out of each one of them before they were tight.
Jeep would not cool and continued to overheat despite no additional leaking. Coolant temp 260 - Oil temp 250+. Shut it down and had it towed via Jeep Care to the nearest dealership. Concerned about the overheating and the potential damage to the engine so I now we wait for them to diagnose it.
Btw...no idea how you guys got to those bolts but you either got some skinny forearms or have gouges in your arms like I do now ?
Remorseless
NC
After I'd seen this thread a while back I'd decided to check my bolts and had the same thought. Need like 3 elbows and arms the size of twigs from a medium height shrubbery to get up in there comfortably.
JimmyB
Berks County - PA
2021 Rubicon
Minor update - Jeep was towed last night called the Jeep dealer this morning (Savage 61 Jeep in Reading, PA) and was told it would be weeks because they have a back log. No courtesy vehicles available because they are 'reserved'. Called Jeep Customer Care and opened a case with them to escalate given the Jeep is less than a year old and obviously a warranty job. Called in some favors from friends/family who know and/or work with other Jeep dealers to see if we can get it in and get a vehicle to drive while repairs are done. 10mile radius forced me to take it to Savage61 otherwise it would have been the very last resort for warranty work...
BigBruse
Robbie
Va
2019 Jeep rubicon
What did you use to get in their to tighten?
