Width for 37s
roaniecowpony
Retired Engineer
Could increasing the size of the shed covering your tool over the years be an impediment! ?
I suppose, but the shed really hasn't been expanded all that much.
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
Given the same PSI (and ignoring the spring effect of the sidewalls, for simplicity, though it's not really negligible it just makes everything a lot more complicated), any two tires will have the same size contact patch, because the pressure of the ground against the outside of the tire has to equal the pressure from the air against the inside of the tire (otherwise there would be a net force on the tire patch and it would be accelerating upward or downward). The tire will deform to achieve a contact patch such that the weight of the jeep on that wheel divided by the air presssure equals the contact patch area. For a narrower tire, what this means is that the contact patch will be longer (forward and backward) to achieve the same area with less width, meaning the tire will deflect more downward to achieve this longer contact patch. Hope that makes sense.
Agree with every thing but ignoring the spring effect of the sidewalls, for simplicity, though it's not really negligible it just makes everything a lot more complicated- it is negligible down to 15 PSI for any tire and close enough to negligible for even bias and E rated tires. The sidewall is not a strong spring.
That's what BT39.com is based on.
And when you say patch, it's not the chalk or paint test patch touching the ground. MT's have deep lugs that are bridged over. Even past the lugs you have the cantilever effect. But if you consider patch size the area including between the lugs, it's a very good approximation.
Wider is generally better in sand, rock, dirt. Mud is a mystery so I won't comment. 98% of the interweb incorrectly believes wider, lower PSI, and bigger patch is better in snow, it's not. For snow you want good pizza cutter studded snow tires (chains the ultimate), fully aired up.
I'm currently on 37x12.5R17 KM3's but ordered Nitto 38x13.5R17 and bead locks.
AZ Hella
Sonoran Desert
JLUR
I'm in the pizza cutter camp. I prefer contact pressure vs. flotation. For the type of wheeling I do and where I usually do it a skinny tire is great. My next set will be 37x11.5 Nitto's.
conFUcius
Stephen
North Carolina
2024 Supra MKV 3.0, 2024 392 JLUR
Medical Affairs
If you go with 13.5”, you can bump people better on the road when they try to merge into you. :rock:
Jeep Wrangler JL Width for 37s 1673528241489
c20040215
Leon
Indiana
Some car wash places don't take 13.5". 12.5" is the max the track would take, unless its a conveyor belt style.
Another factor to take into consideration.
Wicked_JL
Sam
Arizona
2024 Jeep Wrangler Rubicon XR
Data Center Engineer
This thread really needs pictures ? KM3s can be had in 12.5" and 13.5"
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
More tread surface, particularly when aired down, allows the tire to conform around rocks and hard surfaces. And driving in sand is ALL about surface area.
And the "longer" contact patch of the narrower tire provides that, in a better way (length, vs width).
Apples491
Nick
Denver, CO
2022 JLUR in Hydro Blue, 2024 Nissan Ariya
I've slid sideways off of rocks enough that I'd far rather have that width and length-wise really doesn't matter much when your rolling in that direction.
But, I suppose in the end, the preference is entirely subjective.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
You have a point; although I'd say the intended direction of travel is forward or back, even while sliding sideways off a rock, ha.
phageghost
San Diego, CA
2022 JLURD
Thanks, that's super helpful. In thinking about this I've been going back and forth on how much the sidewalls contribute to the downforce, and figured I'd err on the side of caution. But yeah, I can compress an empty tire by pushing on it, which, upon reflection, is going to be negligible compared to the ~1500 lbs of force the weight of the vehicle applies.
And that bt39.com website is awesome, someone really did their homework on figuring this out in quantitative detail, better than back-of-the-envelope speculation any day.
:beer:
  • Like
Reactions: J0E
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
A wider tire will make better contact with obstacles offroad and provide better grip. But, that increased contact and grip means more weight and worse fuel economy.
Thinner tires are better for snow, though I doubt an inch would make much of a difference.
"A wider tire will make better contact with obstacles offroad and provide better grip". I think the opposite is true. Thinner tires can be better in snow.
Apple was pointing out an advantage for each, in its own paragraph. You seemed to have mashed them together. Yes, more surface contact from an aired down wider tire will have more grip than an equally aired down thinner tire.
And yes, a thinner tire will allow it to more easily cut through a layer of snow, to reach the ground below it. That's assuming the snow isn't deep enough to start burying the axle. At that point, a wider tire that can float on top is preferable.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
As posted by phageghost, " any two tires will have the same size contact patch, because the pressure of the ground against the outside of the tire has to equal the pressure from the air against the inside of the tire". So, both the wider tire and narrower will have the same size contact patch.
You're right, it seems I mashed them together. That wasn't my intent, I just didn't create a new paragraph, which I should have. I meant those two sentences as independent.
I believe the narrower tire will have the same amount of tread on the ground, the same size contact patch, but it will be shaped differently. It will be longer, and I think that helps 95% of the time more than a wider patch. I think as you're driving forward or backward, the longer patch provides more traction than a wider tire does. No one has to agree with me though.
Separately, I think a narrower tire can be better in snow, as they cut through the snow; however, just as you pointed out, that's not always better in snow conditions.
