Width for 37s
Allen0jason
Jason
TX
06LJ,
In doing research, I have come across the fact that one tire versus another can be two different widths( Boss AT=12.5 vs Ridge Grap=13.5) my question is given all of the parameters being the same, wheel size, backspacing and everything else, is there an advantage to one width over the other.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
A narrower tire has a higher psi at the ground. Same vehicle weight spread over a smaller contact patch, maybe.
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
A lot of it is going to depend on what the backspacing is on your wheels and how much clearance you have. If your wheels are snugged in pretty tight under the Jeep, a 13.5" wide tire will have a better chance of rubbing at full lock.
Also, your wheel may be better suited to a 12.5" wide (depending on how wide your wheel is) than a 13.5" wide, or the other way around.
13.5" wide will be heavier as it takes more rubber to fill the mold.
13.5" may be more prone to wandering as they will be less likely to sit in the wear grooves on the road, but most 12.5" tires struggle with this anyways, so it may not be a factor.
Personally, I would stick with 12.5" wide if at all possible, but I have also yet to run 13.5" wide. I am sure the extra width will help you out off road, but there seems to be more advantages to the 12.5" wide tire for my particular use case and wheels. I run 17x8.5r17 Method 704's with 4.75" of backspacing (0 offset).
phageghost
San Diego, CA
2022 JLURD
Given the same PSI (and ignoring the spring effect of the sidewalls, for simplicity, though it's not really negligible it just makes everything a lot more complicated), any two tires will have the same size contact patch, because the pressure of the ground against the outside of the tire has to equal the pressure from the air against the inside of the tire (otherwise there would be a net force on the tire patch and it would be accelerating upward or downward). The tire will deform to achieve a contact patch such that the weight of the jeep on that wheel divided by the air presssure equals the contact patch area. For a narrower tire, what this means is that the contact patch will be longer (forward and backward) to achieve the same area with less width, meaning the tire will deflect more downward to achieve this longer contact patch. Hope that makes sense.
[Edited to reflect @J0E's comments about sidewall force]
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Given the same PSI (and ignoring the spring effect of the sidewalls, for simplicity, though it's not really negligible it just makes everything a lot more complicated), any two tires will have the same size contact patch, because the pressure of the ground against the outside of the tire has to equal the pressure from the air against the inside of the tire (otherwise there would be a net force on the tire patch and it would be accelerating upward or downward). The tire will deform to achieve a contact patch area such that the weight of the jeep on that wheel divided by the air presssure equals the contact patch area. For a narrower tire, what this means is that the contact patch will be longer (forward and backward) to achieve the same area with less width, meaning the tire will deflect more downward to achieve this longer contact patch. Hope that makes sense.
Love it.
Apples491
Nick
Denver, CO
2022 JLUR in Hydro Blue, 2024 Nissan Ariya
A wider tire will make better contact with obstacles offroad and provide better grip. But, that increased contact and grip means more weight and worse fuel economy.
Thinner tires are better for snow, though I doubt an inch would make much of a difference.
  • Like
Reactions: J0E
NoahVD
Noah
Ventura, CA
2019 Rubicon Unlimited
I wouldn't say no to an extra inch
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
"A wider tire will make better contact with obstacles offroad and provide better grip". I think the opposite is true. Thinner tires can be better in snow.
Apples491
Nick
Denver, CO
More tread surface, particularly when aired down, allows the tire to conform around rocks and hard surfaces. And driving in sand is ALL about surface area.
  • Like
Reactions: J0E
roaniecowpony
Retired Engineer
When you're already hitting the .. uh .. frame, that inch doesn't accomplish much.
Are ... are we still talking about tires?
It's been quite a few years since I hit the frame.
Borderline Jeep
Houston TX
2019 Jeep Rubicon
If you run on sand a lot, I'd go 13.5. For everything else, I'd go 12.5 for the weight savings.
