Track Bar Bolts Upgrade!
AnnDee4444
'18 JLR 2.0
I mean, there's only so much force you can put into it. At 190 ft lb your front LCA bushings still do this. You've got 2-3 tons of Jeep yanking and pushing and pulling on that bushing, especially when off road, so if 190 ft lb ain't doing it, how much more you willing to try and put in? Personally, I'd rather solve it with a better fit via a bolt vs torque.
You can increase clamping force without increasing bolt/nut torque by using thread lubricant.
Edit: Also grade 9/12.9 bolts have higher tensile strength than grade 8/10.9 (180,000 PSI vs. 150,000 PSI). If you're going to the effort of changing bolts, might as well get one you can torque higher.
Remorseless
NC
That's a little misleading - the bolt is still experiencing the same amount of force on the threads, which carry the clamping load, and your bolt isn't capable of carrying extra clamping load than it was when dry. You reduce the torque to rotate the bolt when lubricated, for sure, but not the load the bolt threads are carrying. You'd end up having to upsize the bolt anyway to have a stronger thread surface to carry the higher load if you wanted higher clamping forces than the current bolt spec allows for without stretching (which, ironically, makes the fitment issue worse). The dry torque spec is what it is in order to fall within the proper safe range for "good enough" clamping but having overhead for thread/bolt strength.
So, if you've got a dry torque at 190 ft lb and you introduce antisieze, and knock 20% off the torque value to have the same clamping force at 152 ft lb, but then you go up to 190+ ft lb to increase the amount of clamp you're getting for the torque value, you're really just stressing the bolt threads, pushing roughly 240 ft lbs of rotational torque's worth of clamping force.
Even then, the question is - Is it enough? Does 240ish ft lb of clamping force not break or stretch the bolt and does that absolutely stop the movement?
My experience - not likely. 2-3 tons of Jeep is just an absolute monster on bushings over time, especially with articulation loads.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Have to be careful there. I think max torque is around 70% of yield, and lubricated increases tension by 30%, so if you lubricate and torque to spec, you may be nearing yield.
AnnDee4444
'18 JLR 2.0
Agreed. Upsizing or up-grading (as in grade 9/12.9 bolt) would be the two real ways to increase clamping force. Lube just changes the torque required to get the clamping force.
And I have no idea what is or isn't enough to prevent movement.
Remorseless
NC
Me neither lol, why I take the easy path and just throw hardware at it.
AnnDee4444
'18 JLR 2.0
$22.29 before shipping for one bolt/nut/washer set
https://boltsandnuts.com/shop/9-16-18x3-hex-cap-screws-grade-l-9-bolts-usa-zinc-yellow-433558
https://boltsandnuts.com/shop/9-16-sae-grade-l-9-flat-washers-usa-zinc-yellow-433954
https://boltsandnuts.com/shop/9-16-18-grade-l-9-hex-collar-locknuts-usa-zinc-yellow-437316
From this chart:
Bolt GradeThreadTorque
(dry, zinc)
Clamp LoadPSI Increase
Grade 9 (above)9/16-18171 lb.ft.21,412 PSI32.5%
Grade 12.9M14-2147.4 lb.ft.18,879 PSI16.9%
Grade 8 fine9/16-18146 lb.ft.18,268 PSI13.1%
Grade 8 course (OP)9/16-12130 lb.ft.16,375 PSI1.4%
Grade 10.9 (not stock)M14-2126 lb.ft.16,154 PSI
GATORB8
CLT NC
From this chart:
(dry, zinc)
vs. Stock
Grade 12.914mm-2147.4 lb.ft.18,879 PSI16.9%
Grade 10.9 (stock?)14mm-2126 lb.ft.16,154 PSI
Stock is M14-1.5
Jeep Wrangler JL Track Bar Bolts Upgrade! 1711645300234-bs
richk225
Rich
New Jersey
2021 392Rubicon XR 2017 Jeep Grand Cherokee
retired due to broken back
AnnDee4444
'18 JLR 2.0
After arguing with ChatGTP for too long (and losing), I'm going to take an educated guess. This chart shows M14-1.5 as being about 7.9% higher than M14-2... which is close enough for me. Just don't use any of the numbers as absolute values... it's just for comparison purposes.
I'm still assuming grade 10.9 on the stock hardware.
(dry, zinc)
Clamp LoadPSI Increase vs.
stock assumption
Grade 99/16-18171 lb.ft.21,412 PSI22.8%
Class 12.9M14-1.5~159 lb.ft.~20,370 PSI16.9%
Grade 99/16-12153 lb.ft.19,193 PSI10.1%
Class 12.9M14-2147.4 lb.ft.18,879 PSI8.3%
Grade 89/16-18146 lb.ft.18,268 PSI4.8%
Class 10.9 (stock?)M14-1.5~136 lb.ft.~17,430 PSI
Grade 8 (OP)9/16-12130 lb.ft.16,375 PSI-6.1%
Class 10.9M14-2126 lb.ft.16,154 PSI-7.3%
Grade 53/4-10227 lb.ft.21,322 PSI22.3%
Grade 21-8232 lf.ft.16,355 PSI-6.1%
GATORB8
CLT NC
(dry, zinc)
stock assumption
I think it might be an 8.8:
Jeep Wrangler JL Track Bar Bolts Upgrade! 1711649911673-it
AnnDee4444
'18 JLR 2.0
OK, let's give this another shot. I know the torque values are going to be different depending on lube/coating, so don't take those as absolute values or torque recommendations.
(dry, zinc)
stock assumption
Grade 99/16-18171 lb.ft.21,412 PSI75.8%
Class 12.9M14-1.5~159 lb.ft.~20,370 PSI67.2%
Grade 99/16-12153 lb.ft.19,193 PSI57.6%
Class 12.9M14-2147.4 lb.ft.18,879 PSI55.0%
Grade 89/16-18146 lb.ft.18,268 PSI50.0%
Class 10.9M14-1.5~136 lb.ft.~17,430 PSI43.1%
Grade 8 (OP)9/16-12130 lb.ft.16,375 PSI34.4%
Class 10.9M14-2126 lb.ft.16,154 PSI32.6%
Class 8.8 (stock?)M14-1.5~95 lb.ft.~12,181 PSI0.0%
Class 8.8M14-288.1 lb.ft.11,289 PSI-7.3%
So back to my original question... is the benefit of changing the bolt really from the diameter increase, or ~50% clamping load increase (assuming torqued adequately)?
From what I've read, most shear connections consider any slip to be failure. I'm not sure it's something I want to allow here.
JLfromCA
JL
2019 Mojito! 2 Door Rubicon/2024 Sarge Green 392
Fine threads ?
