Ospreyfe55
- Marc
- Jan 13, 2021
- Navarre, FL
- 2020 Jeep JLU Rubicon
So I’ve dealt with this before on a TJ and recently seen this talked about on FB. With most people using aftermarket Track Bars, the factory bolts are metric and most reputable TBs are American made and spec’d to SAE bolts. With that said
my recommendation for anyone is to get rid of those factory bolts in the trackbar and get grade 8 9/16”x3” bolts, washers and lock nuts. I had a lot of play in my track bar and swapped out the hardware. It made a noticeable difference in firming up the front end and was the cause of a steering shimmy.
For reference here are my measurements -
MC trackbar sleeve measured .5640” / 14.33mm. Factory bolt is .5440” / 13.82mm, Factory TB is .5580 / 14.18mm and 9/16” bolt is .5625” / 14.29mm.
Even changing the hardware to 9/16” will also benefit the OEM TB. Here is the list of hardware that I got from a local ACE as Lowes did not have the lock nuts.
Front Track Bar Bolts
9/16 x 3” Course Thread
2ea @ 3.19 (Bolts)
4ea @ .75 (Washers)
2ea @ .69 (Lock Nuts)
Total $11.52
2ea @ 3.19 (Bolts)
4ea @ .75 (Washers)
Total $11.52
