Tr4ckD4ys
NY
2025 Jeep Wrangler Rubicon Xtreme 35-inch 2-door, '41 Green
Tech
…but I never got the opportunity to show off my ride on here so below are some pics 😁
Jeep Wrangler JL This is not a build-thread... IMG_5612
Jeep Wrangler JL This is not a build-thread... IMG_5614
Jeep Wrangler JL This is not a build-thread... IMG_5616
Jeep Wrangler JL This is not a build-thread... IMG_5620
Tr4ckD4ys
Tr4ckD4ys
NY
Tech
It looks like a toy car from Dollar General in those pictures. You know those cars I have a giant tires on them?
I like it.
Yeah I’m gonna wear those factory KO2 315/70s down and the switch to some true-to-size 37s
Tr4ckD4ys
Tr4ckD4ys
NY
Tech
You should start one….
Fine. So far I’ve done:
- My sound upgrade, as described in this thread: https://www.jlwranglerforums.com/fo...razy-3800-watt-audio-upgrade-write-up.154480/
- Added the Wolfbox TriPro
- Warn Zeon Platinum 12S winch on stock steel bumper with warm winch plate. I just couldn’t get myself to like the looks of any of the aftermarket stuff (except AEV but that was just too expensive).
- Cheap Amazon Cross Bars with static 200lbs load limit. I think the hardtop has barely any dynamic weight capability but one does what one must when wanting a 2-door wrangler.
- That roam case I had from before, just put it on the jeep. I don’t think I’m actually supposed to mount a crossbar to the gutter of the freedom panels but it works quite well and I carry less than 80lbs load up there. The Amazon bars are actually surprisingly sturdy and functional.
- Metal Cloak Rocklander 2.5” lift kit with rock sport red shocks and upgraded front drive shaft and all of the other boxes checked and marked (HD sway bar end links, track bars et cetera$.)
- Some DV8 LED lights here and there for some necessary illumination at night.
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
Very nice! Love the color.
NXTGENAutomotive
Peak Sponsor (Level 2)
Carlsbad, CA
25 Rubicon XR
Wow, the 2 door in 41 hits different! That's an awesome build and our Cross Terrain removable steps look amazing on your rig!! 😍
dirtwheeler
United States
www.Juszak4x4.com
2025 Wrangler, 1997 Wrangler, 2025 4Runner
Remove the end caps on that front bumper!
I took mine off (factory steel bumpers on a '25 2-door). It looks good, but I ended up putting them back on. The only advantage I could see was for some niche rock crawling situations. Just curious - why do you think OP should take them off? Just looks? My Jeep is pretty similar - 2-door, '41.
Red Rubi 22
Michigan
2022 Rubicon 2 door
Looks and clearance.
