Steering Upgrades when going to 37s?
Roky
Roky
@Roky
What grease brand/part do you recommend for grease gun?
Check with SS and see if they have a recommendation, but I use this for everything except my Rock Krawler stuff….
Jeep Wrangler JL Steering Upgrades when going to 37s? IMG_7732
mrtm1970
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
@Roky
NEED HELP!!! Fing Stock Drag link won’t come off at Pitman arm!!! Using Fork and used heat and penetrating fluid:
Jeep Wrangler JL Steering Upgrades when going to 37s? IMG_0314
Even have other end up high:
Jeep Wrangler JL Steering Upgrades when going to 37s? IMG_0315
Roky
Roky
@Roky
Just keep after it, take the fork out and go in from several different directions, sometimes if you just go at it from the same place you can make it tighter because it kinda wedges it
mrtm1970
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
@Roky
not working 😭
Roky
Roky
Continuing with the Dynatrac Ball Joints in the meantime:
You may have enlist an extra pair of hands, one working the fork, and one smacking the side of pitman, drowwn it PB let it sit a bit, sometimes it takes some doing…..
mrtm1970
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
Drenching it in PB…unfortunately no other hand as my 14 yr old son is Autistic
mrtm1970
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
Just ordered a pitman arm puller that will come tomorrow morning by 8am…will see if I can make something work or at least get it done today
Pulling the pitman arm off the steering box is a good move. Beating on the pitman arm while it's on the steering box transmits each hit into the bearings and gears of the steering box.
Once it's off the box, putting the outside diameter on an anvil and striking the opposite side with a big steel hammer, will elastically deform the tapered hole slightly and break the taper loose from the stud.
mrtm1970
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
Unfortunately I do not have a socket that big
mrtm1970
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
Basically, if it could go all wrong…it has been that way almost every step …. Very frustrating as I was looking forward to doing all this work myself and ALL the videos make it look SO EASY!!! NOT!!! LOL
mrtm1970
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
@Roky
Any trick to get these off?
Jeep Wrangler JL Steering Upgrades when going to 37s? IMG_0323
Banging the shit out of them and used A LOT of PB
I new weighted mallets coming in the morning as well
