Question regarding the Windsheld defrost
willcasp
William
Bothell, WA
2018 JLU Sport S
Good luck with that. I had my dealer look at the issue and they pretty much said “works as designed” (this from supposedly one of the better service departments).
If you do manage to get a resolution to this, please post the service order detailing the work performed so the rest of us can use that as a starting point for our dealer conversations.
What is confusing me here is that looking at the design.. this thing puts a lot of air in the middle.. however, it appears that a few folks have reported getting air on the sides. Is there something in that center plenum that is supposed to be directing air to the sides? Something seems a bit amiss here.
paffemt
Chester County, PA
2019 JLU Sahara
I use a 12 inch wooden ruler to block the center. Has worked for a couple winters now.
Megawatt
Sin City aka Vegas
money pits: Turbo Busa, Street Bob, 22JLUR snazz, 5.0 mustang MT
Powerplant operator
…..Stuff like this makes me hope the Bronco kicks Jeeps a**. What a joke.
Bronco has air vent issues of their own. This is the vent all models have for rear passengers. It’s located under the front seats.
Jeep Wrangler JL Question regarding the Windsheld defrost 0B45EDED-4F54-4794-A27C-4B70A2DBF464
Overland Utah
Caden
JLUR
What's the alleged issue with that design?
The vents are ONLY on the floor, unlike the wrangler which has two conveniently placed air vents in the center console for your passengers convenience.
garyji
Gary
Western NC
Just had to defrost after the ice storm in Raleigh this weekend. Turned it on full blast for about 10 minutes, and everything was melted. No problem at all. Yes, there was more flow at the center, but it did it's job.
G.
Megawatt
Sin City aka Vegas
Powerplant operator
Nothing if you only want air to blow in your toes. And I believe it’s only under one seat so the othe passengers gets nada. There are no moving louvers to direct the flow.
“Alleged” ha ha ha. That’s funny talk right there mr lawyer.
Heimkehr
Pennsylvania
2021 JLU 2.0T
It is when the context-impaired leave us hanging.
Undefined "issues" ha ha ha. That's funny talk right there mr grammar.
And you believe the vent is only under one seat? Do your due diligence and get back to us.
PumpkinMeatloaf
Jeremy
2019 Wrangler Unlimited Sport Punk'n Edition
I just took my 19 JLU to the dealer to ask about defrost blowing from center and not sides, they checked several new jeeps on the lot and say "that it is working as intended." So that was my experience.
KJKWillys
Kirk
CT
2021 JLU Granite Crystal Willys - 6 Speed Manual
Just actually found this thread. I for sure don’t get the “working as intended” Schpeel from dealers. If you screw up a design and that screw up is consistent on every vehicle it does not mean it’s “ok as is”. I guarantee you the group that designed this at Jeep did not intend for it to work this way. It’s not believable that the Test Team did not find this. I’m betting there are internal emails and test reports that highlight the issue but were stamped with “use as is” by Management. I also found it interesting that @JeepCares was very involved in the early posts but seemed to fade away as time and frustration grew. As I read through the pages and pages of posts, I was sure it was going to eventually say that the problem was corrected somewhere along the way between 2018 and today by an in-line design change. Nope. It’s like driving my 73 VW Super Beatle with the air cooled engine in the back with a “defrost” that just blew un-heated/moist air at the windshield. Different problem but you get the point. Clearly, Jeep has no shame.
willcasp
William
Bothell, WA
2018 JLU Sport S
I DM'd some of the folks that had this repaired, and also took a look at the design when I was in the dash working with wiring anyway. The issue folks seemed to be having was air flow was obstructed and not blowing as hard as it should in the center.
Folks that had issues had some sort of obstruction going on, that prevented the design from "working". The root of the problem, the design is crap. It is a single duct in the middle, which explains why the force of the air is in the middle. I get a faint force of air on the edges. The plug technique that folks recommend as a work around is probably the best way to go.
The issue here is the design is essentially crap. You have a main duct in the middle, and the main flow of air is in the middle. The feeble attempt at redirecting airflow is functionally pretty lame.
It should "work as intended".. and the way it works is utter garbage.
JeepCares
Auburn Hills, MI
JL
Thanks for tagging us here, KJKWillys. If you need assistance while at your dealer or want to discuss your concerns further, we are in private message.
Kate
Jeep Cares
DavidArmen
Los Angeles, CA
2021 JLUR
I was under the impression this issue was long understood and it was concluded that it was a design issue, not a manufacturing defect or any other defect. It was just designed terribly.
The small number of people who claim they get air at the ends indeed do get air at the ends, it’s just that the air flow at the ends is less than 5% of the center. Once again, this isn’t a manufacturing defect. It’s just a terrible, inefficient design. This is why the dealers say that it works as intended because it was designed that way. They can’t “fix” something that “works” according to Jeep’s standards.
I drew these diagrams really quick on my phone but you can get the idea of what’s going on.
This is most likely the design of the JL windshield vent:
Jeep Wrangler JL Question regarding the Windsheld defrost 52725807-10FD-47DB-8F70-545900F4066A
Air, like all other fluids, and like electricity, will take the shortest and most efficient path possible. Because the vent from the blower widens up to the entire width of the windshield, it is only physically logical that most of the air will blow from the center, where the air exists the blower vent. There is absolutely no way the air will change direction to the far left/right unless a physical object forces the air to change direction. Because of the fact that 80-90 percent of the air blows out from the center area, it leads me to believe that the above diagram is pretty much how the JL windshield vent was designed.
The unfortunate thing is that it would have been very easy for Jeep to design the vent properly, like it is in pretty much every other vehicle on the road. Here are two very simple designs that would have been easy to implement and that would work well, at least much better than it does currently:
Jeep Wrangler JL Question regarding the Windsheld defrost FF27E27A-8C43-4833-B867-A95DCEB9D1CB
Jeep Wrangler JL Question regarding the Windsheld defrost 937EDA72-08D0-4F5F-ABE2-8DF2CC42A7B6
Hell, even the DIY method that many people are implementing would be much better than the inefficient design they chose to go with:
Jeep Wrangler JL Question regarding the Windsheld defrost 34C95C13-4E14-411E-954C-54947753EB3E
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Better watermark those Dave......don't want anyone stealing it. ;)
KJKWillys
Kirk
CT
I think we violently agree for the most part. The design is crappy (not a manufacturing defect) and they all operate the same with a majority of the air flowing right up the middle. I just find it hard to believe they “intended” it to work that way. Im sure the top level design requirement was to provide air to the entire windshield in order to defrost it more efficiently. If they intended it to just blow on the middle then why extend the ducts all the way on both sides? I also agree that any of your three options would be superior to the current design! Has this forum kinda decided on who’s workaround is the best option? I obviously need one.
