New HD Dana 44 full float axles
AnnDee4444
'18 JLR 2.0
Maybe, but then if they changed nothing else, and FF axles don't really make any difference for towing, then how did the towing capacity go up by 1500 pounds? Unless it was really 1500lb higher all along, and they were just being overly conservative.
The new grill probably allows for more cooling. Also they probably are using the 392/4xe/XR rear brakes to get that rating... but likely a little bit of everything (including the previous measurement being conservative).
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
I recall reading that all models would now have the larger brakes from the 4xe/392
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
I wonder if the front axle is going to be any stronger than current models.. sure.. FF axles rear would allow bigger tires.. but the ones breaking in half are the front axles.. ugh
REDSEAL199
Beau
MO
2021 Wrangler Unlimited Highaltitude 4xe
I thought I read they are adding a tow-haul mode to the jeep. Maybe I miss read it?
GobiWan
Greg
Jeep JLU Rubicon 4xe
Okay, I'm in. If it's plug and play and not ridiculously expensive, I'll give it a go.
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
I'm hoping we can - the current 3500lb towing capacity is almost exactly what my boat trailer weighs, so I'm really pushing the limit (and probably slightly exceeding it when the boat has fuel and gear in it).
Even though I know I can't technically increase the rated towing capacity of a Jeep (what's printed on the door frame is what it is, legally speaking) I'm fine with just mentally knowing that I can safely exceed the rated 3500lb capacity by a few hundred pounds by modding the rear axle to a full float.
When towing weight is usually more of other factors I am wondering how they increased 1500lbs with a FF axle. Going over 3500 with a current JLU the axle snapping in half isn't what I would worry about.
Towing capacity for the European market on the current JL Wrangler is 5500LBS. It's exactly the same Wrangler that's sold here with the exception of some non-towing related stuff. You're fine capability-wise. Though there's plenty of speculation about whether or not you should exceed the US spec when towing.
Jmos4
Jim
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
Hi,
Wondering if this could be fitted to our current 44?
Either way would be neat if they offered it on the front as well, maybe locking hubs on both front and rear...
Maybe some aftermarket suppliers will jump on this?
Regards,
Jim
Zandcwhite
Zach
Patterson, ca
2019 jlur
Even a sport jlu gets a 5k tow rating in Europe and Australia, it was never about the axle.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
XtremeRetard
XtremeRetard
Richard
Rocky Mountains
JLURXR
Even though pinion and gears are likely the same. Im guessing the full float means near zero flex and load across the axle now the wheel load and some flex is removed. Perhpas reducing axial loads on the carrier and gears?
Or am I talking crap? :)
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I've read that one of the strength improvements on the current 44 vs the JK era 44 was larger carrier bearings. The current semi float axle shaft has the potential of bending between the wheel flange and the single hub bearing, because it sees both vehicle weight and torsional loads. The full float has a dual opposed hub bearing setup to fully support the wheel end, allowing the axle shaft to only see torsional loads.
XtremeRetard
XtremeRetard
Richard
Rocky Mountains
JLURXR
Yeah, so has to be better for the gears too I recon.
Beachcomber72
2022 JLU High Tide
I fully believe it has been 5k on the 4 doors all along as in England the current JLs are rated at 5k. They have less restrictions to an extent on certain vehicle functions. So we either had a government policy change here recently in the states or there is truly something in regards to the new axles.
