HungryHound
Thanks for the excellent pricedure write-up! Front was almost 1/2 full at 12k miles with no towing. I cheated and used a torx-key set (pics attached) as the shaft is skinny so you don't have to remove the cap bolts.
Only problem I had was a crappy 6-pt Craftsman 10mm socket broke and stripped one of the diff cover bolts. I switched to a thick-walled impact socket after that to break all the cover bolts loose.
