Is Tailgate Reinforcement Needed?
FitBliss
Gabriel
MN
2019 Jeep Wrangler Limited Rubicon
not to be a dick but do not get the mopar kit, it is not a real reinforcement, if the soft spot the hinges are not changed it does nothing but add weight. I had a rental with the mopar reinforcement on 35's and it flex'd like crazy on the road.
John Galt
Fairfax
2020 JLUR
So you would recommend a hinge reinforcement, or bumper mounted solution? In my scenario, do you think an upgrade is even necessary? I think total weight won't exceed 100 lb.
FitBliss
Gabriel
MN
It's a reinforcement, not a new tailgate. The bracket will make the tailgate stiffer that's it. It won't eliminate all flex.
The rental you say had tons of flex, was it on factory wheels? If not, then the offset of aftermarket wheels will also make this worst by hanging the spare further out and causing an ever bigger lever effect.
Nope it was on aftermarket wheels and tires, not my first rodeo, heard from allot of other people saying the same thing after buying the Mopar setup. I get the idea of backing up the tailgate itself, but I found that when installing one of three different reinforcement kits that the gate is plenty strong, the weak spot is the hinges.
Jeep Wrangler JL Is Tailgate Reinforcement Needed? IMG_3577
Jeep Wrangler JL Is Tailgate Reinforcement Needed? IMG_3581
Jeep Wrangler JL Is Tailgate Reinforcement Needed? 58827920882__05060DCA-6C1F-4B5D-B2FD-DDA7BBEF5BC6.JPG
Jeep Wrangler JL Is Tailgate Reinforcement Needed? 58827750258__5A6A94AE-DD52-4889-B146-6D0421A1074E
Jeep Wrangler JL Is Tailgate Reinforcement Needed? 58827750844__0581A5FD-8E92-4BC9-9D77-2F788FC52B23.JPG
Cody6597
Cody6597
Elliott
Houston
Jeep JL Unlimited Rubicon
I just installed the Roam slimline rear bumper with tire carrier as well. I have some questions about the tension rod--can I trouble you for some pictures of yours and how you did it? Also, it the opening and closing suppose to be stiff? TIA
Did you get it figured out? Sorry for the delay.
yes. Mine is a little stiff but I don’t mind it.
Onward4x4
Nima
Chicago, Illinois
www.onward4x4.com
2018 Jeep Wrangler JLU
Traveler
Yes, I found out it was normal
But, I have a little rattle coming from the tension rod that has gotten be stumped. Do you have any rattles or any noise at all?
Cody6597
Cody6597
Elliott
Houston
I do have some rattling but I’m not sure that it’s from the tension rod. Mine seems to be where the spare tire mount inserts into the carrier if that makes sense.
sourdough
left coast
JL-sold
Hi All. Picking up 38" Pats and hearing they are pretty light. My total wheel weight is 35 lbs and Discount Tire has the Pats at 83 from what I am seeing. I know the set up will fit with OEM steel bumper with my RC relocation but is 118 weight too much for the tailgate?
Thanks.
What other manufacture hangs a big old heavy spare on a door. Just saying.
My spare’s location.
Jeep Wrangler JL Is Tailgate Reinforcement Needed? JL spare's new hom
UTES
Hunter
Salt Lake City
2020 Diesel Sahara, 2018 AMG GT, 2019 MB GLC
Retired LEO
If you go off-road or put a heavier tire on it - YES.
Hunter
rickinAZ
Phoenix
2026 MOAB 392
As a long-time member of the JK forum (I know that we talking about the JL here), I can tell you that broken hinges are a red herring - the tailgate rivets are the part(s) that break. I don't believe that I've heard of a single hinge failure. And...yes, there are folks on that forum, who also are in denial about having to upgrade for 35s and above. That said, the only good carrier is frame or bumper-mounted, IMO.
On the same topic, please answer my question here: https://www.jlwranglerforums.com/forum/threads/tire-carrier-update.45687/
