Tailgate Reinforcement, is it Necessary
Pstric
Paul
Oregon
Jeep JL Sahara
I’m looking at putting 35s on my stock JLU Rubicon wheels. Is it necessary to add a tailgate reinforcement?
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I don't think so, I've read people run a 35 on the factory tailgate.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
That's me... 35 spare on standard OEM tailgate hinges.
Kbinspections
Rich
Kings Park NY
2019 Jeep Wrangler Moab
Goes by weight…..85 lbs (?) and f I remember correctly. Tire weight and rim weight can vary greatly. I have Toyo 35 on stock rims with no reinforcement.
2nd 392
Ca
Depends on the wheel tire combo weight. Stock 7.5” beadlock capable and 285/70 Falken MT’s was ~93 lbs. I wouldn’t want to go much heavier. My 35/12.50 Toyo- 8.5” forged combo is 80 lbs, 2 less than the factory 7.5” beadlock capable and 285/70 KO2’s. … but it wasn’t cheap.
Gobi2
RM
NE Ohio
Gobi JL two door
I put XR takeoff wheels and tires on mine with no issues. However it does just barely rub the steel bumper.
zouch
Berkeley, CA
XJ, JLUWD
depends. what shape do you want your tailgate to be in?
FWIW, Mickey Thompson Baja Boss M/Ts in 35s on Mopar Beadlock-compatible wheels weigh 106lbs. the Mopar Performance Parts tailgate reinforcement does nothing to carry that stress out to the hinges.
yokramer
Snark Incarnate
You dont have to and your tailgate isnt gonna just fall off because you put a 35 on it. But it will close worse, and sag when you open it.
Johnny B
PA
2021 JLU Sahara
I read (somewhere here I believe) it's not so much the size, but the weight. BUT, a larger tire will have more motion to it if not supported properly (up against the stops - anti vibration add ons). Nobody wants a saggy tail... lol
link3721
Tom
North Carolina
2023 JLU Rubicon 4xe High Velocity
The reinforcement acts as a doubler to increase the shear buckling capability of the gate. It doesn't impact the hinges because they aren't the weak point in the design. Any time you exceed the original design parameters you increase the probability of damage.
I got mine with the reinforcement cause I knew I'd end up with larger tires eventually and didn't want to risk tailgate problems.
zouch
Berkeley, CA
XJ, JLUWD
the tailgate reinforcement didn’t prevent my tailgate from twisting.
problem is it does nothing to move the load off of the tailgate.
most of the better setups replace the factory design such that the load is carried through the (upgraded) hinges directly to the vehicle.
yokramer
Snark Incarnate
Yea I had a 35 on the stock gate and stock wheel with the Rock Hard 4x4 brace and it still sagged pretty bad, upgraded to Method 703s and it wasnt any better. Recently put on the CavFab carrier that replaces the hinges and it shuts better than any stock gate Ive ever seen.
Johnny B
PA
2021 JLU Sahara
Haven't seen a single soul have any bad words about that CavFab stuff.
yokramer
Snark Incarnate
Yea I will 100% be buying more of their stuff. Quality is amazing, support is quick, welds are art and the price cant be beat.
Johnny B
PA
2021 JLU Sahara
They utilize machine welding if I recall reading about that company. Those welds, perfect every time. Unless the machine goes off. I love it when machines go off. Watched a Haas machine obliterate bit after bit on incorrect input data... lol
