Installing Mopar Tailgate Reinforcement ...
Nikko2020
DG, IL
'20 JLUR, '21 4R TRDP, '21 Supra, '72 442
Going to install the Mopar Tailgate Reinforcement today hopefully. Anything I need to be aware of? Looks pretty straightforward. Advice from those that have done it? Thanks and be safe out there!
plex
Cincinnati, OH
Weekend keyboard mechanic and beer drinker
Go gently on the hinge bolts, they will be a little bit stuck because of the paints. Break the paint with gentle tap first.
Be sure to mark your gate in relation to the body with painter tape or marker, they may move when you took off all the hinge bolts. Use some shims to hold it.
Martindfletcher
Martin
San Diego
Ducati 1299s, 2018 JLUR
make sure you use the right size torx, there is so much paint that it appears to be a smaller size than it is. They do supply different bolts so if you don’t swap it for a newer setup it does matter that much.
Nikko2020
Nikko2020
DG, IL
Have shims to hold it in place hopefully. If it moves, I assume I just re-align and tighten the bolts up?
plex
Cincinnati, OH
Yes, and if you are going to put on a much heavier rim+tire, it actually helps if you shim up a little more so the sag will be offset.
Nikko2020
Nikko2020
DG, IL
Stock upgraded Rubi rim with a 35" Nitto RG. Although it's a heavy tire, I don't think it'll be too bad with the stock rim.
