Ideal offset/backspacing JL
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Rubicon doesn’t help me that much since my axles aren’t as wide. I think I am in the 0 to +10 range. Seems to put me about 1.5-2” outside stock. Front tires have about 3/4 inside fender now, so may be about what I need to stay legal here
You want a 0 offset at most if you want to stay close to inside fenders. I run a 9.5” and -18 offset.
Pdiehm
Paul
Newark, DE
AML Investigator
Jeep Wrangler JL Ideal offset/backspacing JL 3874D3C4-0B8A-4387-8588-4699DEC1CC21
yeah, they are sticklers here at inspection time. Maybe 1.5” outside fender I can pull off. If I calculate right, 0 on a 9” wheel is 5.25” backspacing. Pushes my wheel out .75”. Then another 1” or so for the 11.2” tire and I am probably 1-1.5” outside fender.
actionplus
Randy
Rancho Cucamonga Ca
2021 JLU Rubicon
I've got a 21 JLUR.
Planning to get the Fuel Covert D716 17x9. They come in +1 or -12 offset.
It will be wrapped with 35 KO2.
Really do not want it to stick out too much. Maybe an inch or so. Would -12 do the job? Anyone has one of these they can share pics of?
Pdiehm
Paul
Newark, DE
AML Investigator
I've got a 21 JLUR.
from what I understand the rubicon axles are 1.5” wider than sport and Sahara.
A +1 will be 43 mm or roughly 1.7” further out than stock. -12 would be 56 mm further out, or over 2”.
both instances in Delaware are illegal. +18 is as far as I can go and that’s about 1.25” outside the Sahara fender.
actionplus
Randy
Rancho Cucamonga Ca
2021 JLU Rubicon
Hmm, might not want more than 2". Was looking from something close to 1-1.5".
Stuckinthesand
CJ
NJ
Do they actually pull people over for the tires sticking out in Delaware? NJ has the same law but most of the Jeeps and off-road rigs all run wider tires that are past the fenders. Hell I even see some people with no fenders. So far I haven’t gotten pulled over(as I knock on wood) and I run a -18 on a sport.
Living Good 357
Big D
Pa
C7 Z06, 07 Dodge Cummins, 900 HP 72 Nova
Heyyy guys & Gals! I have a 2021 Rubicon that I'm looking to mount a set of 37-13.5-18 Toyo m/t on these rims,(18"×10" with a -24 offset) does anyone know how far the tire tread would stick out pass the stock fenders?? Thanks in advance 👊🇺🇸👍
PatRodriguz
Patrick
Mississauga, Ontario
Hi all, I'm looking to get 17x9 0 offset rims installed on a 21' Rubicon. I'm having a hard time finding pics of that specific setup on stock suspension. If anyone can help link me with that setup, it would be greatly appreciated. I'm scouring the internet and forums as we speak, tough luck so far.
ittessor
Rich
Long Island
2018 Jeep Wrangler Sahara JLU, 2017 Dodge Challenger R/T Shaker, 2013 Chrysler 300S
IT PRO
Check out Custom Offsets site. They helped me with my setup when I got my JL in 2018..
ejewels
CT
2021 JLUW - Black
This is the reason 35's work on the new Rubi , But again there are different wheels and tire combinations that might require BS
But not on the sahara to now fit 33s? Pretty sure the Sahara and Willy’s or even sport s have same width axles on JL
