Got Mopar 2 inch lift do I need to do alignment?
Pn221
Peter
2018 Jeep Rubicon
Instakled the 2 inch lift and the Jeep dealer says there is no need to do alignment on the truck is this true??
Jeep Wrangler JL Got Mopar 2 inch lift do I need to do alignment? 8578BEA4-16ED-4795-AC76-08EE903D4043
Jeep Wrangler JL Got Mopar 2 inch lift do I need to do alignment? DD275F6A-F0EF-4674-8B13-C4782F82A252
Spank
I didn't need one. I adjusted my drag link and that was it.
drogers
Livermore CA
F-250
If you take for granted that it was properly aligned from the factory, you’re probably fine. OTOH, you just dropped $2k on a lift - what’s another $70 to have the alignment checked?
Jammer
Ft worth
Bright white JL Rubicon
Am i wrong or does it look like those springs are already collapsing ? I know mopar has said they are replacing all the springs out there that have been put on.and the new kits are coming with a better made spring. there are pictures and post on here about this problem with the mopar front springs collapsing
Jammer
Ft worth
Jeep Wrangler JL Got Mopar 2 inch lift do I need to do alignment? mopar springs bowin
Here is a photo someone posted of the springs collapsing
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
The only two knobs they can control for the alignment is the tie rod to adjust toe and centering your steering wheel. For the lift install the tie rod doesn't get touched so really no need there it's the rod that connects both front tires. The steering wheel will be negatively affected because the drag link needs to grow it connects the steering box to the front passenger tire, if you feel like you steering wheel is not at 12 o clock for you to drive straight it should be adjusted but not pressing matter.
The other measurements in a alignment would more or less check if your axels didn't get bent so really no need
Jammer
Ft worth
I am not a mechanic but that doesn't look right. Those Springs look like they're collapsing. Is that the way they're supposed to look after you install them ? I've never seen springs look like that after they've been installed on llift kit. Everyone's been saying the Mopar lift the front Springs are collapsing thats why they corrected it and they're sending new ones out to replace the ones that are out there now that are bad
Jammer
Ft worth
I have never heard of anyone doing a lift kit before and not having it to do an alignment. I would spend $70 and have alignments but that's my opinion it's your Jeep you can do what you want
Scottroxxx
NJ
18 JLR
Poet
I'd be more worried about those springs.
Jammer
Ft worth
That's why I'm glad by the time I get my JL in about 8 weeks they'll have this problem corrected.. I was told Mopar is sending out them improve Springs to all the dealers this month
boogie
kelly
jeep jl
If you did a lift you spent good money on tires so I think it would be worth the $70 to make sure those bad boys last
Jammer
Ft worth
If you did a lift you spent good money on tires so I thing it would be worth the $70 to make sure those bad boys last
I agree with that. Tires are not cheap
Joe Paul
Jax, Fl
2018 Wrangler Unlimited Sahara
I installed that lift and had the alignment done, which is a good rule to follow. It was off slightly, so I'm glad I had it done.
Jammer
Ft worth
did you not put the isolator in that's to collapse looking you're supposed to have a new isolator where doesn't collapse like that
offcamber
Bob
Dallas, TX
2012 Wrangler Unlimited Rubicon, 2014 Grand Cherokee Limited Ecodiesel
It's completely unnecessary. The ONLY thing you can adjust on the Jeep as far as alignment is toe in. You can adjust that yourself easily using a tape measure and chalk. Paying for an alignment on a Jeep is just silly and a waste of money. I've had over 10 lifted Jeeps and not once did I ever get an alignment on any of them.
