Got Mopar 2 inch lift do I need to do alignment?
swampflyer
rick
florida
retired
curious if anyone is running caster in the 8's. 8.2/8.3 and no lift. How does it drive etc?
Zandcwhite
Zach
Patterson, ca
2019 jlur
How and why? No lift but spring for adjustable LCAs just to run more Caster than you need? With no lift the downward pinion angle might not be enough to cause driveline vibes in 4wd, unless of course you never you 4wd or never go over 25mph in 4wd and then it doesn't really matter.
Roky
Roky
Caster should be adjusted to compensate for the decrease that occurs when lifting…..In addition to pinion angle Zach mentioned, it can also lead to oversteer due to jacking effects when entering a corner…..I always adjust in enough caster to make it drive sweet…….just not a good idea to add excessive amount imho……
