Dynatrac Ball Joint Issue - Need advice.
JustSendItDude
Dustin
North Richland Hills
2020 2DR Rubicon
Yes, it slides over both. I think I did just that —slid the collar on the inner, put the outer shaft in, and then slid the collar like you describe to be on both, as that lined up with the fork on the FAD cover when I put it back on.
Did you struggle getting the collar onto the inner shaft? It seems like it wants to line up, but won’t slide onto the inner shaft. I guess it’s gotta be absolutely perfect to slide on
azwjowner
Phoenix
I didn't. Don't you have the FAD open at this point? You should be able to just put the collar on the end of the inner shaft, far enough that it won't fall while you slide the outer in. Like 2 seconds with your hand.
JustSendItDude
Dustin
2020 2DR Rubicon
Yeah, that’s all correct. But for some reason, I was struggling getting the collar to slide onto the inner but I finally got it. Does the inner and outer shaft need to be touching or is this gap ok? Seems like the axle shaft can’t go in any further but I see a slight gap still.
Jeep Wrangler JL Dynatrac Ball Joint Issue - Need advice. imag
azwjowner
Phoenix
So I can't say I looked at the width of the gap -- but it makes sense that the two can't touch because you need them to not rub when disconnected -- it's the sliding of the collar across both axles that locks them to have 4WD.
Plus, once you fully tighten the hub to knuckle bolts (the 12pt ones), there is no way that the outer axle won't be exactly where it should be. It's all fixed.
JustSendItDude
Dustin
2020 2DR Rubicon
Appreciate all the help! Damn feels good to do this stuff on your own. (With a little help from the pros). Going to button up this side and get started on the driver. Who knew a set of ball joints would be a 4 day job……
Remorseless
NC
No, to get oil into the FAD the seal is moved outboard of the FAD. That said, there's minimal oil in the FAD when opened, because it's just what has splashed side to side while the vehicle was in motion. The fill level isn't that high.
Interesting engineering decision on behalf of Jeep/Dana, assume it's to get a little oil to the intermediate shaft bearing? Only thing I can think of that would like some lube in there. Doubt much gets up towards the collar.
azwjowner
Phoenix
My collar was lightly coated in oil when I removed it. No way you want to slide a dry collar back and forth. Remember when you shift on the fly into 4hi at up to 55 mph, the inner shaft has been spinning backwards because of the spider gears. The outer shaft is spinning forwards at full speed, and the collar is meshing the two.
Roky
Roky
Don’t worry, it gets plenty of oil, lol….this the rear diff but you can see how fast the oil gets everywhere soon as the ring gear gets going
Remorseless
NC
I guess I always figured the collar and bearings were well out of the way of the ring gear splash given they weren't super close to the ring gear and that most of the work was done by the bevel on the collar and the hardness of the material for the shafts and collar. TBH, even with a light coat of gear oil, not wild about the FAD mashing things together at 55. If I was doing a lot of that I'd look into a FAD delete, personally.
I'm just so much more used to thinking of the gear oil slinging being for the bearings in the case I don't even think of the FAD. Feels so far away from the diff, breaks my head a bit to think of the oil slinging making it that far laterally lol
JustSendItDude
Dustin
2020 2DR Rubicon
Well guys. I thought I was on the final stages of finishing. Got the other two ball joints installed and knuckle put back on. Threw the axle in which seemed to seat just fine and got the 12 point bolts in the back torqued down. But now when I spin the axle with my hand, I hear a clicking noise inside the axle tube near the diff. Is it possible the axle didn’t seat properly? The other side doesn’t make that noise.
I’ll get finished at some point. But some insight on the axle noise would be fantastic. I’ve read some folks say it’s normal, but I don’t remember spinning the axle and hearing that noise before.
azwjowner
Phoenix
What diff do you have? Open? Locker? Is the FAD still open? Can you spin the wheel and look inside the FAD to see if there's any slippage with the collar?
I can't say I've spun just one JL front wheel like that, so not sure. But if it's an open diff it should be quiet.
JustSendItDude
Dustin
2020 2DR Rubicon
I’ve got a front locker. FAD is closed back up already. This is on the driver’s side too. Which I thought was a simple pull out, put back in and no collar to worry about.
Gregj
Greg
West Texas
This doesn’t happen in a vacuum, when you pull the lever back you are also engaging the front driveshaft which will stop the spiders and inner shaft from spinning backwards. I bet there is a delay in the FAD engagement too.
Gregj
azwjowner
Phoenix
I'm not sure about the front lockers in a JL making that noise. Probably it was there before and you didn't notice. Perhaps someone else with a front locker can chime in.
Edit: I started to say engage the locker and try it but I don't think you'll be able to do that without locking the two axles in 4wd, so nothing will spin.
JustSendItDude
Dustin
2020 2DR Rubicon
I’m going to pull the axle shaft back out tomorrow morning and try reseating it. I don’t know what else could be the issue right now. Don’t have the energy to keep troubleshooting tonight. I’ll check back in tomorrow. Thanks again for the help.
