- Nov 29, 2023
- the cornbelt
- '21 JLR 6MT
- Banned
- #16
So you didn't freeze it did you?
They’re in the freezer right now. Thought I’d give it one more go with another suggestion first before freezing.So you didn't freeze it did you?
I'm looking at more complete kits on Amazon and came across this adapter. It looks like one side is raised more than the other. Is this something along the lines of what you are talking about?It isn’t going in straight because you need a different adapter that accounts for the angle. These usually aren’t included in those ball joint tool kits. It’s a thin adapter shaped like a wedge, thinner on one side than the other.
Use care taking the ball joint back out and it won’t be damaged. Also, use anti-seize compound on the joint so it slides in easily.
Yes, that’s what you need. Align the clamp so you’ll get as straight a press as possible.I'm looking at more complete kits on Amazon and came across this adapter. It looks like one side is raised more than the other. Is this something along the lines of what you are talking about?
10-4. Thanks for the help. Ordered a kit with the adapter pictured above. Fingers crossed with the freezing and correct adapter, I can get these bad boys installed.Yes, that’s what you need. Align the clamp so you’ll get as straight a press as possible.
Yes, sir. Using anti-seize from the get-go. I'll do more ball joints in the future, so I'm going to invest in a good kit to keep at the house. Thanks again for the help!Don’t forget the anti seize. AutoZone may have the adapter. Good luck!
