Differential oil change
The Fixer
North Jersey
Teacher
Yes, do go with 75/140 front and rear..
In the last 2 days, I have done 7 diff fluid changes and 2 transfer case fluids for other people's JL's..
Today, I will do my JL's diffs and transfer case ...... will also do diff fluid on a gal's JT.
You're keeping busy!
So, here's what I wound up with today. Front diff fluid was golden brown and super clean - I could see right through it when it was draining, even though it has 30K on it. The rear fluid was icky again after just 15K miles - black, and I think a little sparkly. I know the clutches wear on these units, but hopefully it's not actually bad.
The Fixer
North Jersey
Teacher
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
jwilson2899
Front Royal, VA
2020 Gladiator Rubicon Launch Edition
Out of curiosity, was there a change in the recommendations or service manual? When I did this a couple years ago the service manual page you posted called for 75/140 in the back and 75/90 in the front. That was also what you recommended at the time and what I went with. Just curious since it’s that time again on mine.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@jwilson2899
Yes, I use 75/140 front and rear these days...
Read here:
https://www.jlwranglerforums.com/forum/threads/differential-oil-change.47318/post-2164946
Rhinebeck01
Retired at 55 ..
How much do you charge for the fluid changes?
I have the vehicle owner order/buy the fluids and/or parts ... I give them links to go to and buy.
They bring me the vehicle and the fluid/parts and usually wait for me to do the deed... usually they go for a walk for a while.
I do this stuff on the side (I'm retired and do not need the $) for affluent guys/gals that have money to burn so to speak. I just tell them "give me what you think is fair.."
Can tell you, I always have them give me way way more $ then I would quote them to do the deed.
Again, they have $ to burn. They are appreciative to get it done right and not to have to deal with the dealer, etc.. they know I treat their vehicle like it was one of my own.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Out of curiosity, was there a change in the recommendations or service manual? When I did this a couple years ago the service manual page...called for 75/140 in the back and 75/90 in the front. That was also what you recommended at the time and what I went with. Just curious since it’s that time again on mine.
If I had to guess, I'd say some owners are voluntarily choosing to use 75W-140 instead of 75W-90 based on their individual use cases and/or personal preferences. The printed gear oil specifications for my F&R axles are the same as what you mention.
Rhinebeck01
Retired at 55 ..
Little to no 4 wheel driving and yup, front diff fluid will look like that..
Don't forget to do the transfer case if you have not done so...
Cost syou say $28 for the ATF+4 and takes little time, effort and know how to do.
Gmanjeeper
Arkansas
2022 JLR
Are you still recommending Valvoline 75w140 both front and rear?
bumpit
2022 Grand Cherokee 2019 JL Rubicon 2018 370z
I've run this a few times front and rear. Currently running amsoil extreme gear oil but had no issues with the Valvoline 140 in both.
CarbonSteel
Any 75W-140 will fill the need. I have been running Valvoline but have ran M1 and Amsoil as well. Dana specifies 75W-140 in both axles; FCA specifies 75W-85 to meet CAFE requirements.
Gmanjeeper
Arkansas
2022 JLR
Thanks. I only have around 7500 on my 22 JLR, but I am going to add after market diff covers and so I will, of course, be adding new gear oil. Thanks again.
Gmanjeeper
Arkansas
2022 JLR
I am putting the Dana Advantek covers on.
