Differential oil change
roaniecowpony
Retired Engineer
If I had the differential that was too hot to touch, I would first check the level. If that was OK, I would drain and refill with fresh oil. Probably a different brand. I'd also check the drained oil for evidence of excessive wear. While I was in there I would visually inspect the gears. If excessive heat persists, I would pull it apart and check bearings.
CarbonSteel instrumented his axles and found his ran oil temps comparable to engine oil temps. I don't recall the specific temps, but it was hot. Also, Jeff pointed out that there was a difference of ring n pinion ratios.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Ratios shouldn't have any difference. If they're set up right with good lubrication you should see similar temps.
In this case, there were two Jeeps that did the same drive. They ended up with significantly different temperatures. The one running much hotter has something wrong.
roaniecowpony
Retired Engineer
Possibly. My original post was to point out that touching the surface can be misleading as to temperature inside and that cast iron isn't somehow eliminating more heat than the stamped cover, possibly quite the opposite due to the coating.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
That's possible. A coating on the cover could make it feel cooler. Though after a long drive, even a coated cover would heat soak.
roaniecowpony
Retired Engineer
Remember those Shuttle tiles...
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
jadmt
jeff
montana
I dunno I would think traveling 75-80mph there would be a difference simply because the 4.56 will be spinning faster...might not be enough to matter but maybe not.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
If the bearings are in good shape, the difference will be negligible.
But the reason to get the shorter (higher number) gears is because the taller tires rotate slower and all you're doing is putting the driveshaft back closer to the same rotation speed that it had with shorter tires and taller gears. It's not like you're going to be spinning the driveshaft super fast.
