Difference between 2H and 4H AUTO on dry roads?
lindaspins
Linda
Burton, OH
2015 JKU Rubicon Hard Rock
A fellow with a 4xe did an 80-mile road test, once in 2H and once in 4H Auto and compared MPG. 2H was 19.6 while 4H AUTO was 23.8 even though the Jeep people said their engineers found there is "really no difference".
The fellow acknowledged the 2H 80-mile trip was hilly while the other one was not. But a 4MPG difference?
He didn't say how he excluded the battery for these tests while, in a subsequent video, he said he depleted the battery to calculate MPH but that video was not a 2H vs 4H AUTO comparison.
As my vehicle won't be 4Xe, I kinda set his test aside.
Wrangler mileage is so variable anyway that it's really hard to pin down what causes differences. Variations in speed, cargo, wind direction, pavement-it all makes a difference. All I know is that if I had to pick one of our two Jeeps and sell the other, the 4xe would win every time.
Panda Mafia
Canada
JLUR 4xe
I have tested mine a few times. Always have similar mileage. Summer time weather obviously. Then again I don't care about mileage. Winter time if my gf driving the Jeep, it's safer, I feel better knowing that. Plus I have way too much fun with it in 4Ha on snow roads. My 4xe 95% of its life has been in 4H auto.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Better mpg in 4A means you can throw his test in the trash. I doubt it makes much of a difference having the front axle engaged vs not in 2H, but any difference it does make favors 2H by simple physics. Neither JL we've owned has had 4A, so I don't have any real world experience, but why anyone would drive around in 4A spinning their front driveshaft needlessly in dry conditions is beyond me if 2H is an option. The wear difference will be as minimal as the mpg difference, but it still favors 2H. On a 392 I believe the Tazer can enable 2H but I'm not sure there.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I'm just trying to find out as much as I can before buying a Jeep which may be a 392 where I would have no 2H with which to compare to 4H AUTO. Curious, too.
If you're thinking about buying a 392 and any concerns about "does (whatever) impact mileage?" then you're looking at the wrong engine. The 392's mileage is absolutely horrific. That's not what people buy it for.
Note, however, that you can get a Tazer and enable 2H with the 392. That's intended for burnouts, however, and not for any perceived increase in mileage.
kmmn
Martin
Maryland
2021 80th Anniversary EcoDiesel, 2013 JK Sport & 2014 JK Sport
In 4 auto, the front axle shouldn't engage until the transfer case senses slippage... then typically a viscous coupler engages the front output shaft and you're in 4wd. It's great for slick wet/snowy roads. I would have gotten it, but it wasn't available on the EcoDiesel
Zandcwhite
Zach
Patterson, ca
2019 jlur
In my opinion/experience if you drive aggressively in a non-392 JLU on big tires your mileage is going to be pretty close to that of the 392 anyway. Our 2019 on 38s with the 2.0t got mid 16 mpgs on average and closer to 15 at freeway speeds. This mileage didn't change much when we regeared from 4.10s to 5.38s. That brick into the wind thing needs all the power it can get. Out 2022 with 35s and a 3.5" lift averaged low 14 mpgs and would drop into the 13s at freeway speed with 4.56 gears. Now with 39s is averaging high 13s. Now granted we do drive on the faster/more aggressive side, but with the 392s power to spare I'm guessing you'd actually be easier on the skinny pedal. Most guys seem to average in the 12-14mpg range on their 392s which is right in line with our 3.6L mpg. If you're concerned with mpgs I would not but a wrangler period. Can you hypermile an ecodiesel into the high 20s driving 10mph under the speed limit and drafting semi's everywhere you go? Sure. My buddy with an ecodiesel on 37s who drives like I do averages 14-15mpg on the way up to Tahoe. I'll just but gas and get to the wheeling destination asap, but to each his own.
Zandcwhite
Zach
Patterson, ca
2019 jlur
The drive shaft isn't engaged, but the fad is, which means the front driveshaft is spinning although under no load. Like I said the drag and/or wear will be minimal but they still exist.
kmmn
Martin
Maryland
Right, the drive shaft is still spinning and there is wear (I miss the old days of locking hubs)
Zandcwhite
Zach
Patterson, ca
2019 jlur
I'm all for the push button convenience at this point in my life. Shift in and out of 4wd at any time? Push a button to disconnect the sway bar? Another button for lockers? Adaptive cruise control so I can just set it and go? Sign me up.
Zandcwhite
Zach
Patterson, ca
2019 jlur
The fad doesn't control when 4wd engages if 2wd is slipping. That's a function of the tcase.
True, but putting the tcase in 4A engages the FAD so that the tcase can immediately shift in and out of 4wd via the viscous coupling. 2H is the only mode in which the fad is disengaged.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
True as well. Some of the statements gave me the impression it was all FAD is all. Having finally fixed my tcase issues after 3 years of "Serv4wd" I am a little passionate about the POS 4auto tcase. (Which actually isn't a POS, lol)
Zandcwhite
Zach
Patterson, ca
2019 jlur
I don't live where it snows and if/when I head to the mountains looking to go snow wheeling I know I want full time 4wd, thus I've never owned a wrangler with the 4A. Extra complexity and wear parts that I have no need for.
sunset
sunset
Jay
Seattle
1984 Camaro Berlinetta V8, 2024 Wrangler Rubicon 392
Oh, I know how impractical the 392 is.
It's not that this is a deal-breaker but this is all new to me and I want to know what you guys know and I am here right now and y'all are so helpful and I am analytical to a fault...
My delving curiosity always makes me look overly-concerned. LOL. It's how I teach myself.
You're the second person who has said this. I can check into it to educate myself but my first thought is how I would shift into 2H given the pattern portrayed on the shift knob itself:
Jeep Wrangler JL Difference between 2H and 4H AUTO on dry roads? 2024 Rubicon 392 shift kno
sunset
sunset
Jay
Seattle
Well, Jeep is saying the front axle in 4H AUTO is always engaged to some degree in anticipation of slippage and that engagement affects MPG.
What he said. ;)
