Check your windshield bolts
flyer92
Nevada
Just a small drop of Blue Loctite should keep them from loosening, but since I take them out regularly, I just torque them to the spec'd 14 Ft-Lbs.
Thanks for posting the torque spec for these bolts. Where did you find this?
Erievon
Al
Cleveland, OH
23 JTR, 21 JLU (Low) Altitude
Thanks OP. My 23 JT, only 2k miles, and the the one furthest left on the driver side wasn't even finger tight, completely lose. It never rattled, but I'll be darned, once tight it reduced wind noise a little bit!!
Wifes 21, all 4 were already tight, but I've never touched them.
Someone mentioned the speaker grills in the sound bar, all 8 in both were loose too.
Ormond Beach, Florida
Retired at 55 ..
I was in the back cleaning the interior windows and while doing that I remembered the same post you read in regard to the 2 speaker grills on the sound bar. Got out a Torx driver and checked mine and...... all 8 were quite loose.
au176
WNY
2021 Islander, 2020 Newmar Ventana, 2014 HD Road King
Tired again
Somewhere on here, I believe. I'll see if I can locate it. I downloaded the whole thing and edited it down to my needs.
au176
WNY
Tired again
flyer92
Nevada
zouch
Berkeley, CA
XJ, JLUWD
i checked the windshield bolts on my '21, and they were all solid.
i have also been using the single-screw visor reinforcement screws plate, and they've worked fine. (that was the only kind i knew of when i got mine years ago.)
i did, however, find the replacement screw on one of those coming a little loose; the original screw was fine.
Thanks, I found the single screw version so a i’ll try that first. According to the amazon reviews it works well.
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
i have also been using the single-screw visor reinforcement screws, and they've worked fine. (that was the only kind o knew of when i got mine years ago.)
The original screw is long enough for the new bracket? So far mine seems to be holding.
zouch
Berkeley, CA
XJ, JLUWD
at least on the kit i got some years ago, only one of the screws was replaced; the other was re-used.
the original, reused one is the one that's still holding tight for me. go figure!
(i had to update that earlier post of mine; i should know better than post before the second cup of coffee has kicked in!)
SaintNick
St. George, Utah
2023 Jeep JLU High Tide
Geez now I'm going to go check every visible bolt inside my Jeep. Thanks for that.
Slippery Pete
Zach
Central PA
2022 JLUW XR 2.0T
Checked mine. Middle ones were tight. Driver side tightened 1/8 of a turn, passenger one was really loose. Snugged it up. Thanks!!
UPDATE: No creaking on the way to work this morning!!
ObiMatt87
San Antonio, Texas
2024 Anvil JULR XR, 2018 Mojito Sahara JLU, 2018 Buick Enclave Avenir
USAF Active Duty (Retired), DAF Civilian (Current)
There are four recessed T40 bolts, two on either side of the upper windshield (inside the cabin). They tend to work loose and cause mysterious rattles. The wrench in the green canvas Jeep tool kit will fit. Take a moment and tighten yours.
Thank you for this! Geezo, my two outer bolts were ridiculously loose. Inside two were tight. We'll find out in the morning if that helps eliminate one of a few rattles that developed following a recent trip to Arkansas where we did a fair amount of off-roading. Either way, these needed tightening. Thanks again! ?
