Changing oil weight
TNjeep615
Tennessee
2021 Jeep Wrangler Rubicon Unlimited
Hey,
So I’ve read a few things about swapping from 0w-20 to something a little thicker in the 3.6L. I’m due for an oil change and was wondering if I should swap to a 5w and if now is a good time with winter almost here. We live in TN so winter isn’t too harsh but it can get to the double and single digits occasionally. I’m at 58k miles on my stock 21 JLUR.
Also, plan to replace t case and diff fluids. Not sure if myself or the shop will do it, depends on how much they quote. Other than a “multipoint” inspection, is there anything else I should do or check?
Any advice is appreciated!
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Hey,
I just put mobil 1 5w-30 in mine. Great for winter. I would also consider doing your transmission fluid if it's the automatic.
Pape
Quebec
JLU Sahara
Try to keep the winter grade at 0 if possible. Winter grade is everything before the W. The number after the W is operating grade, this is the one you wish to increase when you say you want to go up in grade. Oil viscosity is a simple sliding window in temperatures and viscosity.
Blacksport
Ft Lauderdale
'25 Wrangler Sport S, 3.6/manual trans...'23 Corvette C8...'25 Yamaha XMAX
I'm in South Florida, I use Valvoline Advanced Dexos 5w-30 during the summer...during the cooler winter months, I use 2 quarts of 0w-20 (same exact Valvoline oil) and 3 quarts of 5w-30, which makes 3w-26. Whatever oil & weight you use, make sure it says "dexos", developed by GM & Mobil 1 for less wear at start-up...
roaniecowpony
Retired Engineer
... ...during the cooler winter months, I use 2 quarts of 0w-20 (same exact Valvoline oil) and 3 quarts of 5w-30, which makes 3w-26. ...
Jeep Wrangler JL Changing oil weight dog tilt
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I assume @Jeep Junkie has some thoughts on this, but are you thinking you know something that Jeep's engineers don't? And do you have an understanding of the implications of the Stribek curve?
_olllllllo_
William
The Wild Wild West in AZ
2019 Hellayella JLU Rubicon 6-speed
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
I run SAE 30 non-detergent. Its what my great grand pappy ran.
Jeep Junkie
Muhammad
Seattle, WA
2024 JL Wrangler Willys
But Engineers also say follow the oil life monitor while running the crappiest MS-6395 0w20 out there, change the coolant after 100,000 miles, and never change the transmission fluid 🫣🫣🫣
