Camber Issues
Kratos
Wes
jacksonvile, Florida
Just checking to see if anyone knows what the issue is here. Whenever my front end is facing downward on a slight decline, the wheels get very cambered. When the jeep is sitting level or facing upward, i don't see any problem. Is this normal?
Jeep Wrangler JL Camber Issues 1705603702485
Jeep Wrangler JL Camber Issues 1705603645746
Jeep Wrangler JL Camber Issues 1705603780388
Roky
Roky
Where is your axle shaft ? Lol…
Jeep Wrangler JL Camber Issues IMG_9720
LazyJL
Larry
2020 Rubicon, 2001 built XJ
Retired fabricator and mechanic
The axle's nut holds the unit bearing together, it looks like the unit bearing is falling apart
Reinstall the axle, torque the nuts to specs, and see what it looks like.
You run a good chance of the unit bearing falling apart while driving.
Kratos
Wes
At the time of these pictures, I was waiting for a new shaft to come in the mail. I should have posted a newer picture for reference, but the jeep still has the same camber issue with the axle shaft installed.
Organic Gasoline
Travis
2020 Jeep Wrangler Rubicon
If you wheel this vehicle, I would check the aluminum knuckle. These can bend and break off, also note the torque for the ball joints as it is really low.
Lower Ball Joint--15lbft/Upper Ball Joint 55Lbft- Lower Ball Joint--15lbft/Upper Ball Joint 55Lbft-
Don't guess!
If it is indeed bent, look for the JT Mojave knuckle as they made those with cast steel vs aluminum. Reid Racing makes them as well.
Otherwise you have yourself a bent ball joint. The camber is not adjustable on these.
Old Jeeper
Don
US Army Infantry, IT Engineer
X 2 on that
jeicamakzsym
Schaumburg
2020 JLUR
Your ball joints are bent … I had the same exact issue took mine apart and check this out
Jeep Wrangler JL Camber Issues IMG_1765
Jeep Wrangler JL Camber Issues IMG_2021
AnnDee4444
'18 JLR 2.0
mwilk012
2018 Ocean Blue JLU Rubicon
Service
This thread is 5 months old. The OP's wheel bearings likely fell apart within a few days of his post.
But nice ball joints. Absolutely wrecked them, lol.
RhinoJLU
Ernie
New York
JLU
I’ve never seen anything like that in my life wow. I’ve k my seen balljoints break off completely
angrykitty
Severance, Colorado
2024 Jeep Wrangler
That's less camber than I have. Yay me using the search function, let me add to this.....
How much +/- camber is acceptable? I have -.4 and -.5 degrees. SPC recommended .75 to bring me to 0 and +.1.
Is -.4 and -.5 degrees really bad? Could it cause a shimmy in the steering wheel? I'm about to put on new Dynatrac ball joints and Rustys steering system to try to get rid of my shimmy. Those inserts are $50 each. If I can help it, I'd like to avoid another $200 if my camber is acceptable. These readings are "in the green" on my alignment sheet, asking the smart collective anyway.
Nokones
Kenny
Sun City West, AZ
There is nothing wrong with that much of negative camber. It's better to have a tad of negative camber static than positive camber. This setting will ensure that you are running on the entire contact patch with the outside tire in the turns, depending on how much caster you have.
Positive camber will cause the outside tire to run just on the outside edge of the tire while in a turning maneuver.
Camber won't cause a shimmy situation. An incorrect toe adjustment or loose steering components and/or a poor quality steering stabilizer. The lack/incorrect caster setting could contribute to a shimmy situation along with poor hub bearings, bent wheel, or out of round/ squirmy treadblock on the front tires. Another contributing factor could be your track bars not centering your axles and of course the associated potholes that you will be running over.
