Bottle Jack Recommendations
JPROCKS
JPROCKS
Graham
BCS Mexico
2024 Jeep Wrangler Rubicon X 3.6L
This is probably overkill for a bottle jack, but I got one of these. They're pricey, but my hope was that it would be better built and not end up leaking. Two plus years later it still hasn't. I even use it for doing my tire rotations.
What tonnage did you get ?
You must pack light on everything else to have room for that when wheeling and camping lol
These 1.5 ton Pro Eagle jacks are pretty small for a floor jack. 35 lbs. or not much more than a HiLift Also, ProEagle makes a bracket that can be adapted to go on the rear rollbar diagonal.
JEEP4U
Richard
2021 Jeep Wrangler
I'm on 40's and this US Jack works great...............
Jeep Wrangler JL Bottle Jack Recommendations 1720824885993-6l
smokeythecat
2021 Willys Sport 2-door, 2019 Mini Cooper S
I'm pretty sure it's just the little one, 3-ton. Given the curb weight my 2-door Wrangler I figured that was plenty good. Plus, it fits in easily in the under floor compartment in the back.
Membrain
Dirk
DFW TX
'21 XR392 / '24 XR392
Engineer
KG4NEL
Hillsborough, NC
2025 Unlimited Rubicon X, 6spd, 4.88s
I found one originally sold with Sprinter vans, already has the axle cup welded to the top.
Glen722
Glen
Peoria, AZ
'20 Rubicon JLU
I'm in the same "overkill" camp (especially if I'm under the Jeep). I have a 3-ton US Jack. Made in good old USA. I also got some Safe Jack accessories for any contingency. Everything fits perfectly in an Anvil tool bag I got at Home Depot. My US Jack lays on its side in the bag and has never leaked. I've used it quite a few times on trails on lifted Jeeps running 37" tires without any problems.
Gorilla57
Chandler AZ
2019 JLUR Mojito
When I looked into getting a bottle jack, I couldn't make the math work.
I'm on 37s with a 17" wheel. That leaves 20" for sidewalls total, or half that at 10". The axle tube is 2.75" diameter or 1 3/8" radius. When my tire is flat, the axle tube could be as low as about 9" to the ground. So, the jack needs to go as low as 9" ish then raise at least 10 or 10 1/2" or 19 1/2 - 20". Find me a bottle jack that does that.
Here ya go....
https://www.jlwranglerforums.com/forum/threads/best-trail-bottle-jack-rubicon-jl.47578/post-2338793
THAW
Foster
23 JL4DrRubicon
Assuming only 1 flat and using trigonometry, place the bottle jack as close to the center of the axle as the diff allows to get a significantly higher starting point and requiring approximately half the ram stroke.
By my math, you should be able to use a bottle jack with ~11" (or less) minimum height and ~6" ram stroke.
THAW
Foster
23 JL4DrRubicon
Jeep Wrangler JL Bottle Jack Recommendations 1000002392
I carry two 4 ton bottle jacks; both fit in the jack compartment (at the same time). I have a bunch of Safe Jack attachments for versatility and frame leveling at camp.
