Beadlock fail at SEMA causes broken leg
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
Using a trim ring and trim bolts instead of the beadlock ring and beadlock bolts could have caused the ring to blow off the wheel in one piece.
It's on the ground in the last photo and looks warped/bent.
Don’t think it’s even physically possible to mount a beauty/rash ring in a beadlock position (i.e., mating surfaces, bolt length, etc.). However, it’s SEMA, so no telling how many corners may have been cut to make it to the show. Mock up gone bad?
JamesWyatt
New Mexico
2025 JLUR X
Yeah, who knows. Maybe they had the right bolts on the right ring but only torqued them to 2lbs instead of 20lbs and then tried inflating the tire to 100psi thinking it was 100% ☠
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
I was watching the tire change kid do my tires on a Focus RS I had. He blipped them on with an impact, even though I specifically asked them not to. I let it go and kept watching. Then he goes around with the torque wrench and "checks torque". After he did all 4 he backs the car out and I come walking over. I asked him what the torque was and he was like "100lbs" (I don't remember actual RS specs) when I asked how he knew, he said he torqued them. I said after you used the impact, "yep". Argues with me that the wrench is clicking so it was proper torque. Sigh
At that point I just went to Service Manager and got new lugs bought and tried to get the wheel studs replaced as well but they wouldn't bend on that. Lol.
Moral of the story, a lot of people don't have a clue how a torque wrench works at all.
My Ryobi Impact has an automatic mode that limits tightening to 20 ft/lbs (not for beadlocks but great for lug nuts). I watched Costco mount my KM3 and they used a cordless impact driver that must have a similar feature, because I watched him tighten them with the torque wrench and they all turned quit a bit before it clicked.
My neighbor is a hot head and got in a dispute with Costco and claims Costco intentionally cross threaded 3 of his lugs. Costco agreed to pay for the repairs so who knows. He wanted to make money off the deal so I used my impact to remove them. Two of the cross threaded barely came off with all 1,170 ft./lbs. Breakaway Torque, the 3rd one sheard the lug stud.
Which beadlocks do you have? TrailReady says to never retorque the bolts after initial torque. If a bolt comes loose, they say to deflate and retorque with new bolts.
https://static1.squarespace.com/sta...7fbd443e0/1654197965653/HDbeadlockinstall.pdf
He's not retorquing them, he's checking them. Otherwise how do you know if they've come lose or stretched?
Here's what the manual says
NEVER RE-TORQUE BOLTS AFTER INITIAL INSTALLATION. IF BOLTS COME LOSE, REMOVE THE VALVE CORE AND REPEAT STEP 4 WITH NEW BOLTS.
It is recommended that the operator visually check the beadlock bolts after each use
Visual inspection isn't a reliable way to know a bolt is loose.
So how do you know if they've come loose?
Per the same instructions, more failure modes
  • In any beadlock system, torque from the loads placed on the tire is transferred through the beadlock clamp to the bolts and can cause even grade 8 bolts to break from time to time. When changing tires, do not reuse existing hardware.
  • DO NOT EXCEED 22 FT.LBS ON THE BEADLOCK BOLTS.
  • DO NOT ALLOW THE END OF THE STARTER BOLTS OR BEADLOCK BOLTS TO DRIVE INTO THE WHEEL.
  • ** If the thickness of the tire bead, at 22 lbs ft., leaves a gap between the rim and ring, you will have an improper assembly, the result of which is potentially going to fatigue the bolts over a period of time and cause them to break.
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
After reading through this thread, I've come to the conclusion that beadlocks are one huge pain in the ass. One I never intend to have.
There are a lot of people who will come on here and speak very ill of things they have zero experience with/in. Conversely, there are people who will speak adamantly on something they have zero experience with/in. The true conundrum of the internet!
roaniecowpony
Retired Engineer
For my current uses, I have no plan to use them either.
Pig-Pen
Banned Camp
2018 JLU
jabroni
yeah i almost bought a set a few years ago. Thank goodness i didnt. I have yet to even attempt to tackle anything gnarly enough to warrant their usage.
and i live in CA, didnt want to go through the hassle of the background check and two week waiting period.
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
Also... some tire beads are really thick and require spacers between the wheel and the ring, otherwise, it will cause the ring to buckle before reaching the appropriate torque values, bending the bolts inwards, which of course will fatigue them and possibly cause a catastrophic failure of the bolts, and well... send the ring flying..
  • Like
Reactions: J0E
MattJL
JL 2.0
Too bad to hear about the beadlock issue. Good thing it it not included in any of our plans.
KoKo
Karim
2022 Jeep Wrangler Unlimited Rubicon Diesel
Looks sweet, I’ve got some in satin black on mine. Been running them for almost 7months now.
I hesitated a while between the two colors. But ultimately went bronze. Did you have any issues with the o-rings seating properly and not shredding?
Jtclayton612
Memphis, Tn
2020 JLU Sport S
I actually had discount tire mount them, everything worked out fine on them.
That bronze was definitely a good call with that color. The bronze wouldn’t have looked good on a white JL I don’t think, especially with as many black accents as I have.
Gorilla57
Chandler AZ
2019 JLUR Mojito
If you read what he wrote, he said he was retorquing them.
I check mine by putting a socket on and give it a gentle twist, as 22ft/lb isn’t much.
  • Like
Reactions: J0E
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Ya, it was just a normal, run of the mill impact. Wrench clicked instantly. Kid was clueless.
