Good Job!!!Well i finally got around to starting this project. Removed the reflectors and had to do a little hacking but everything fits nicely.
That looks rather cool, more details please.Well i finally got around to starting this project. Removed the reflectors and had to do a little hacking but everything fits nicely.
Nice job!I have the parking sensors. Here's my thread on installing flush mount Rigid Ignite lights in the bumper. Hope it helps
https://www.jlwranglerforums.com/forum/threads/rigid-ignite-backup-light-installed.19307/
@IndustrialAction
As mentioned in past posts here, indeed no diode is necessary is you go directly from the auxiliary lights to the Aux wire.
As for the inexpensive diodes... in the past I used them, say with with external wiring, and they just did not hold up to the elements.
Sure they will fair /work well for awhile, and then they die.
Best bet is to just pay for the pricier/beefier/Weather friendly, Roadmaster diode's or similar.
Again, the cheapies will work, work great and the price is right...... but they crap out, and usually do so when you are on a road trip and that ain't fun..
Note: For hook-ups with diode staying inside, using the passenger footwell Aux, the cheapies are aok.
It wasn't hard to do BUT I had to come out right by the rear bump-stop. I couldn't see a good way to get down the hump in the frame-rail. It is a wicked bend and you've got the tire, shock, bumpstop, muffler and all that in the same area. I just came out by the bumpstop and ran the wire up over everything and zip tied away.@IndustrialAction
Forgot to ask.. Another forum member is saying that running a wire through the passenger side frame rail of a 4dr. JL is a major issue.(for him) Did you have any issues? I doubt you did.
How about telling of your wire run in frame rail experience..
I know running a wire through the 2dr passenger side frame rail is easy easy.
@IndustrialActionI would normally agree but wiring is something I do all the time in my non-Jeep hobby. I use diodes all the time in high and low power scenarios and I've never had one fail in several years of doing this. What it really comes down to is the user's ability to (1) solder and (2) heatshrink/weather-proof. A [properly] soldered diode is not separate, get water in, or any of the other things that could potentially happen to one of those huge $25 things. Plus, there's nothing to mount/hide really. A 15 amp diode is about the thickness of your pinky and maybe 1/4-1/3" wide.
I have no beef with anyone using the big ones. I just want to let people know that there is another option and if I were using one in a dual back-up/Aux scenario, I'd pick the solder-in version.
Agreed that @Colorado Rubicon's install is probably the cleanest out there thus far, but it's a no-go for folks like me with the steal bumper and proximity sensors. My search continues...I'm confused about the diode requirement. I understand that it's like an electrical check valve to keep energy flowing one direction only, but are they only required if you want to control the aux backup lights separate from the reverse lights? I just connected a lighting relay with the trigger off the backup light circuit and main power to the lights through the relay. I only use them when in reverse so I have not wired up to an aux switch. In this case I'm presuming no diodes would be necessary.
My favorite install so far is the one by @Colorado Rubicon surface mount. My solution was much less elegant. If these get damaged or broken off I'll likely go with the surface mount floods. But until then these work just fine.
If you're going to tie something in to an existing circuit (like the back-up wiring) you need to use a rectifying (rectifier) diode. Due to the sensitivity of the computer system, if it reads an abnormality (unexpected condition) when sensing the connections, it might throw a code/not work as expected. The rectifier diode means that the power flows to your add-on but that no chatter/feedback comes back into the line which has the potential to mess with the expected conditions the computer is looking for.I'm confused about the diode requirement. I understand that it's like an electrical check valve to keep energy flowing one direction only, but are they only required if you want to control the aux backup lights separate from the reverse lights? I just connected a lighting relay with the trigger off the backup light circuit and main power to the lights through the relay. I only use them when in reverse so I have not wired up to an aux switch. In this case I'm presuming no diodes would be necessary.
It was intended to isolate the additional load of the aux LED lights from the reverse light circuit (however small that additional load may be)... figured it couldn't hurt any. Also could bring in an aux trigger to the switch circuit for the ability to turn on w/o being in reverse... would probably need the diode to keep that from feeding back into the reverse light circuit.Personally, I don't see a need for an additional relay unless the power is coming straight from the battery to the add-on
Totally agree! I over engineer everything too haha. I'd rather be overbuilt than underIt was intended to isolate the additional load of the aux LED lights from the reverse light circuit (however small that additional load may be)... figured it couldn't hurt any. Also could bring in an aux trigger to the switch circuit for the ability to turn on w/o being in reverse... would probably need the diode to keep that from feeding back into the reverse light circuit.
Besides... Overkill is Underrated!![]()
