Backup Lights
mdallas
Martin
New England
BMW X5 M50i, BMW X5 40i, JLU Sahara
So I'm planning on adding the Ignite lights for reverse. My plan is to tap into the White with orange stripe wire out of the trailer wiring for power to both lights (with a diode after the tap). I also plan to run a wire from the Aux switch into the power of the lights (with diode). Does anyone see any issue with this? Has anyone tried this setup before?
I am going to power the F111 fuse with the AUX 3 switch. Maybe a diode there to be on the safe side.
Ormond Beach, Florida
Retired at 55 ..
As long as you use 2 diodes in that mix like you say, all will lets say play together without problem. Suggest you read this thread from page one until this last page. Yes, myself and other's have done this install. For the record, I have had no Can Bus issues, probably because of using two diodes in the mix.
What are you plans for grounding those Ignite's? You can pick up (tap) a ground wire in the same bundle as the white wire with orange trace. I did not want to compromise a second wire in the bundle so used a self tapping screw in the rear tow cross member and used that for a ground versus tapping into the ground on the bundle.
Let us know when all is done....
ar15rifle
Heath
Kansas
18 JLUR, 05 BMW E46 Conv, 04 E60, 15 Fiat 500C, 70 Ford F250, 05 Camry
Thanks for the tips. I've read the thread a few times I just wasn't quite sure as I'm not an electrical person I prefer to research allot and double check everything, hence the specific post. My brain doesn't always seem to work as everyone else's so I'm a bit cautious with a vehicle we plan to keep for retirement. As far as grounds I plan to use self tapping screws into the tow cross member as suggested (I'll solder/crimp the ground wires together and then solder/crimp a ring onto the ground wires that I'll attach to the screw).
They work with the Aux switch, but I'll have to wait until the wife is home to test the reverse, but overall I think it's good. Here's how the finished product looks:
Jeep Wrangler JL Backup Lights IMG_0026
Jeep Wrangler JL Backup Lights IMG_0027
sjl136
New England
'24 Willys 2dr, ‘90 YJ, '22 4Runner
Thanks go out to @mdallas for posting his set up. I duplicated it and what an improvement the @BajaDesigns S2 Sport makes back there. I ended up running power all the way up to the under hood Aux switch connections for Aux3 after deciding to go without the reverse actuation for now. Snaking the power through the frame rail was pretty easy with a wire coat hanger, and then added a bit of wire loom to protect where the wire comes out of the rail up to the engine bay. And yes, the Jeep could use a bath.
M1kefries
Chesapeake
My take on the rigid ignite light. Only wanted it for backup so just grafted the flush mount into a receiver cover and tied the wires into the trailer light plug with a weatherpak connector. When it gets dark we’ll see how much difference it makes.
Jeep Wrangler JL Backup Lights 530D9637-0D9C-47EC-9A50-2777E27D8AE6
dugout68
Doug
The Emerald Coast
2019 JLUR (ordered), 2018 Dodge Durango GT, 2015 Wrangler JKU
Business Analyst
LouNYC
Lou
New Jersey
2018 Jeep JL Sahara
dugout68
Doug
The Emerald Coast
Business Analyst
Thanks for posting. I am going to order a pair of these. Does anyone on here have them mounted? I do not have the tow package and want to run them to aux switches.
What is the best way to run then to front of car while having wires protected?
I'm planning to attach to aux/reverse lights in tow package, maybe someone else can help.
melendez69
Marc
Waxhaw NC
...huh?
InspiredEngineering
Sam
Miami
2018 Rubicon JL, 2013 JKU on 60's, 1997 TJ on D60s
How interested would you guy be in a kit that replaces the factory reflectors on the bumpers with a pair of flood LED lights?
It would be a complete kit designed for the JL, with wiring and everything.
I do think you would have to cut the bumper behind the reflets asd it is solid if im correct. WOuld that change anything?
PaPasJP
Gainesville, FL
Interested, but what are we talking about as far as cutting the bumper out? Taking it off and having it Torched or drilled and ground down? That is a lot of work.
Got to have something as far as a good light source as the stock ones are trash.
Torero
J. Diego
Illinois
JL Rubicon, FJ Cruiser, BMW Z3, F650,GL63 AMG, STI
Very interested. Plastic bumper should be way to cut.
bam1111
Barry
Maryland
Has anyone tried adding a brighter LED diode in place of the factory one?
