jgo138
- Justin
- Nov 8, 2018
- San Antonio, TX
- 2019 Sahara
- Occupation
- Education
Ok I’ve gone through every post in this thread at twice, and still at a bit confused about where in the line to put the diode(s). I want the lights to come on with reverse, and also run to aux switches, but I’m not using the factory setup. I am using the Rough Country MLC-6, which runs separate from the CanBus system. https://www.roughcountry.com/mlc6-multiple-light-controller-7096c.html
I have no problem running wires and tapping into or splicing wires, but I am still confused where diodes would go with this setup. Do I just need one between the Aux switch and the tapped connection? Do I need an additional diode between the tapped connection and the wire to the extra lights?
