Anyone using Rough Country Diff Skid Plate?
Derek
Derek
MA
2018 JL 2-Door
When Installing this will I loose diff fluid? Wasn't sure with just two bolts.
4 bolts, but mine didn’t and I put them on and back off several times (feels like I’m jinxing myself as I’m typing this)
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
Ordered a set of the RC covers yesterday., the ebay Rough Country store has the best price that I found, $75 for the front and the back. Pretty heavy too, pkg info said 25lbs for rear & 15 for the front.
lol at the vehicle compatibility charts on the ebay listing though, unless Rubicon owners swapped their tasty Dana 44s for our lowly D30 & D35 diffs then they will have fitment issues :headbang: :headbang:
https://www.ebay.com/itm/Rough-Coun...for-18-20-Jeep-Wrangler-JL-10624/363030485332
https://www.ebay.com/itm/Rough-Coun...for-18-20-Jeep-Wrangler-JL-10623/362994428479
They also have the Rubicon skid plate on their own website. I would just order straight from the manufacturer and cut out the middle-bay.
https://www.roughcountry.com/jeep-jl-m220-diff-skid-plate-10628.html
Ruby Mike
Southern California
2020 jeep wrangler diesel
I had mine installed and no problems. No leaks, I really haven't tested the skid yet.
AZHUND
Tucson, AZ
2018 JLU Sport S, 2018 CX-5, 2020 RAM 1500 BTS
I am interested in these but confused on their fitment guide. I have a sport with LSD so is a M220 rear axle per my build sheet. However the m220 rear diff skid plate from RC says ONLY for Rubicon... so are they wrong or what rear diff skid plate am I supposed to get?
blnewt
New Mexico
Just ask @cosine he knows!
You need the M220 (Dana 44) skid plate.
blnewt
New Mexico
AZHUND
Tucson, AZ
I agree that would make sense, I am just hung up on what they say on their website. Anyone out their already try the m220 one on a sport?
Jeep Wrangler JL Anyone using Rough Country Diff Skid Plate? 54FFD861-2D71-42C9-AEEB-EEB92EA0DC19
blnewt
New Mexico
AZ Hella
Sonoran Desert
JLUR
I also had to pull the front skid as it made contact with my oil pan/transmission skid plate support.
blnewt
New Mexico
Got them installed, must say I'm 100% satisfied w/ the fit & function of these plates. No bending, prying or hard time trying to get everything lined up. All the cover bolts lined up perfectly, the retention hanger in the back of the plates secured the skids nice & tight, and the drain hole F&R also lined up just right!
I measured a before & after~ the lowest point at front diff was 11.25" from the ground, the lowest point on the skid was 10.5" so a 3/4" drop in clearance in front. The rear was 10.75" before and 10.25" after the skid was installed for a 1/2" loss in clearance, not bad at all :)
There is nice coverage over the rear driveshaft to pinion mount too. I used a floor jack to get the rear skid lined up as it is pretty heavy and wanted to make sure I had all 4 of those bolt hole lined up, worked out well. Only concern is if it's still ok to jack it up under the rear skid now, this thing is solid as a rock but being mounted to those 4 diff cover bolts I'm not 100% sure???
Jeep Wrangler JL Anyone using Rough Country Diff Skid Plate? IMG_0522
Jeep Wrangler JL Anyone using Rough Country Diff Skid Plate? IMG_0524
Jeep Wrangler JL Anyone using Rough Country Diff Skid Plate? IMG_0525
Jeep Wrangler JL Anyone using Rough Country Diff Skid Plate? IMG_0526
Jeep Wrangler JL Anyone using Rough Country Diff Skid Plate? IMG_0527
MntsRcalln
Virginia
2020 JLUR, 2011 Dodge Ram Bighorn, 1990 Totoya 4x4 Mod
Anyone used a jack on the front plate? Pretty sure it would support it. Was just wondering.
CO4WD
2019 JLU Sahara
I installed front and rear RC diff skid plates on a 2019 JLU 2L Sahara with Dynatrac 2" lift and the rear has interference with the 48V battery factory skid (driver side) just like the previous 2 door post. Removed it on the trail to stop the metal on metal tapping, need to grind it down and reinstall.
Jeep Wrangler JL Anyone using Rough Country Diff Skid Plate? 20210226_113226_resized
Jeep Wrangler JL Anyone using Rough Country Diff Skid Plate? 20210226_113124_resized
AZ Hella
Sonoran Desert
JLUR
apparently the new ones have a notch for the 48v battery.
