Actual height difference between Rubicon and Rubicon XR?
Jtphoto
Thunder Bay ON
2022 Rubicon Xtreme Recon Granite Crystal
I’ve had my XR beside a number of Standard Rubicons. I can confirm there is an average 1.5” increase in suspension height and another inch increase from the taller tires. Putting 2.5” springs in an XR will only net you an extra inch.
Vatdevil
Rob
Mars, PA
2022 Rubicon 2 Door 6 Speed
My XR with factory winch seems to include the correct front springs, finally (IMO). I was at 21.50" (front) shock eye-to-eye.
Same on mine with XR winch front springs
AnnDee4444
'18 JLR 2.0
Sorry, old habit. For some reason I had those in my spreadsheet as a JLUR.
I've been waiting to see what application 68540221 is used in (yours are 68540220). They might be a slightly taller version of the JLR XR spring... or maybe they're rear springs (like 68540222 - 68540225).
proptied
WI
22 JLR Snazz, 24 JLUR Earl
Nope, trust your gut; you were right, anyway (those were JLUR XR). I keep getting sucked into these 2 door threads forgetting I no longer have a 2 door.
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
Here are a few generic shock eye-to-eye lengths that I've been using. These could be +/- 0.5" (or more...) depending on the Jeep, but are a rough average of where each one sits.
ModelFront shock eye-to-eye @ ride heightRear shock eye-to-eye @ ride height
Sport18.5"21.2"
Rubicon20.0"22.5"
XR21.0"24.0"
Got a 21 regular Rubicon. Thinking of installing some 3/4 spring spacers since I already have them but I also need shocks. Would XR takeoffs work ya think?
AnnDee4444
'18 JLR 2.0
Maybe, but a spacer is a guaranteed 3/4"
AnnDee4444
'18 JLR 2.0
I was meaning the compressed and extended length compatibility.
Sorry, I misread the first post. Yes you can use XR shocks, but you should also adjust the bump stops to match their compressed length. I have 392 Fox shocks on my JLR with +1" bump stops. The front endlinks might be a little too short also, but I've had it totally flexed out without issues (still might be worth watching/changing)
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
Np. Thanks for the feedback. If I have the compressed regular Rubicon shock measurement from your spreadsheet, just add the difference between that and whatever shock’s compressed length I end up with is and add that much bump stop if I understand correctly.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Yes, but adding bump stop to run different short stroke stock shocks is not something I'd do. The xr shocks still only have 8" of stroke despite the same compressed length of most aftermarket 1-3" lift shocks that have 10"+. You can run metalcloak rock sport shocks with the same amount of added bump stop and 12"+ of travel. Why leave 50% of potential suspension travel on the table for no gain? The rock sports dampening is very similar to the stock Rubicon shocks so the ride will be basically the same with way more droop.
AnnDee4444
'18 JLR 2.0
I got my 392 XR Fox shocks as take-offs for $300, and it was about $125 for Metalcloak bump stops & take-off XR endlinks... so about the same cost as the Rocksports. I'm fairly certain they ride better than the Rocksport shocks, and I know they're much better than my stock Rubicon shocks, even at OEM Rubicon height.
I didn't lose travel, I traded it for ride quality.
Zandcwhite
Zach
Patterson, ca
2019 jlur
The fox shocks may ride better than rocksports, that I don't know. I have run both the stock xr shocks and rocksports and they ride very similar. If you're happy with it that's all that matters. Personally I'd trade 50% more suspension travel for the same money even if the ride quality wasn't quite a good. In reality I spent twice the money on fox 2.0s on this Jeep so I got the best of both worlds, improved ride quality over stock and a lot more travel.
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
I called Metalcloak and they recommended the 5100’s for only a 3/4” spacer. I can’t swing the Synergy 1” springs I had on the other JL right now. Based on the stock springs with a 3/4” spacer, and looking at any shock below $700, the only options where I won’t lose flex seems to be the 0-1.5” lift 5100 and Fox 2.0 monotubes. I liked my Foxes I had before I took over the wife’s Rubicon. The economy is kicking our butt and I’m just trying to maximize my maintenance dollar.
