looks good! any power increases? how does it sound?
Does that exit in front of the axle? How difficult was the removal of the original exhaust pieces required in order to install this? Looks like it includes a resonator?
it exits before the axle, yes there is a resonator in there. Install took about a hour it was very easy.Does that exit in front of the axle? How difficult was the removal of the original exhaust pieces required in order to install this? Looks like it includes a resonator?
This morning I installed the same exhaust on my JLUR. It is a little louder, but not obnoxious. I'm not sure if it will get louder over time. I wanted something that flowed better, weighed less than stock, tucked up high and didn't drone at highway speeds. All of those goals were achieved.Just installed the Borla climber touring and it’s very quiet. I barely noticed a difference from stock. Does it get louder with break in? Maybe I should have got the stype. At least it is around 18 pounds lighter than the stock one.
I don't have any experience with any of the systems you mentioned, but here's another option: https://www.quadratec.com/p/hooker-headers/axle-back-exhaust-kit-muffler-jeep-wranglerWell, I decided to try the muffler delete this past weekend. I removed the stock muffler and installed the Dynomax Elimination Pipe. I really like how much room it frees up in the back, but it's pretty loud upon startup and in higher RPMs (lower gears). It's too loud for me, so I'm looking into some other options.
I stumbled across the aFe Rock Basher Cat Back System and thought that it might be a little quieter than the Dynomax elimination pipe (the aFe Cat Back has a muffler and the Dynomax doesn't), but I'm worried that it'll still be too loud. Any thoughts? Will the straight-through muffler on the aFe Cat Back be just as loud as the Dynomax elimination pipe?
I definitely want a better sound than stock, but I don't want it to be too loud. I'd rather avoid the dual-outlet axle back systems because they look a bit bulky and they're really expensive. If anyone has some tips on where to go from here, please let me know. A bolt-on system is strongly preferred (I'd like to use the stock hangers). And of course, the less expensive, the better (I'd like to keep it under $500 if possible).
