2.0l turbo question
Ericl
Eric
Illinois
2019 Ram 1500 Laramie
Quick question, is the 2.0l a single or twin turbocharged engine?
Thanks
Jeepney Johnny
Rico!
2020 Jeep Wrangler Sahara
I suspect the eTorque part of the mild-hybrid system is what really makes the 2.0 turbo feel so good. The Wrangler doesn't need a smaller sequential turbo, because at low RPM, there's an electric motor twisting the driveshaft with a belt.
Now, you can get the 2.0L engine without eTorque, and this C&D article reads, " It's difficult to detect any difference between the 2.0-liter with electrical assist or without," but how can that be, when you're missing 70 lb-ft of instantaneous eTorque? But the same article does also read, "the automatic [transmission] is programmed to help mask any hint of turbo lag as the engine revs".
Hmmm. My only electric vehicle experience is with indoor go-karts, motorcycles, and bicycles, and it feels amazing how that instant motor torque scoots you up to speed. That's why I thought the electrical part of the eTorque system deserved more credit.
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
From what I’ve read the ESS and gear shifts are smoother on the e torque. I can attest to that...
SecondTJ
Il
Jeep
The driveshafts are not being turned by a belt when BSG is active.
eTorque has the same problem with the 90 lb-ft unit on the 3.6 or even the 130 lb-ft unit on the 5.7 Ram, it’s barely noticeable. It has such a small operating range, idle to ~1500 rpm before the gas engine’s torque overrides the systems output.
Hothead Headliners
