GrayWolf.Overland
- Subash
- Sep 9, 2021
- Maple Ridge, BC, Canada
- Website
- www.instagram.com
- 2025 JLU Rubicon (Anvil Gray)
- Build Thread
- Link
- Vehicle Showcase
- 2
Thanks for the explanation @Fudster . Does the following statements right now considering your explanation above.Later model 2018's and model years beyond, and those early 2018's with TSB 18-092-19 will, upon detecting a dead or unconnected Aux battery not crank, but on second user attempt switch all power to the main battery and turn ESS off, displaying that ESS is off in the dash EVIC.
After one disconnects the AUX and sees the above-mentioned EVIC for ESS off.. they may choose to live with it OR they can go ahead and remove the Fuse 42 - in which case it will suppress the ESS Off EVIC message.
Using ESS in such a setup (Aux disconnected, Fuse 42 removed) is perilous as it means there is one battery for everything - i.e. you can drain the main battery even in one ESS Stop event in case you have enough aftermarket electronics connected.
