MEHillwalker80
Will installation of this kit affect warranty coverage?
Great question...Will installation of this kit affect warranty coverage?
This true but not a fully robust answer. What I understand to be true is that if the after market mod cause a problem with something else, then the “something else” is also not warranted.If you remove a factory part and replace it with an aftermarket part then that piece is no longer under factory warranty.
The bumper to bumper will not be affected. The Magnuson-Moss Act protects you.
It's explained in detail when you open the link.This true but not a fully robust answer. What I understand to be true is that if the after market mod cause a prI OEM with something else, then the “something else” is also not warranted.
steering is a good example. Put on a 6-inch lift and 40-inch tires. Go to the dealership and complain about a steering problem. You will likely not be getting warranty work to diagnose the problem.
