Where to get Gladiator Grill Inserts?
ProjectJL
Joshua
Los Angeles
2019 JLU Rubicon
Indeed, I would assume minimal improvement, but I'm no aerodynamics engineer. Anyone try the 850w fan in a JL yet?
This would be a really nice swap. Can someone find a part number? Will it fit the 2.0? I think that extra cooling could be amazing especially for the turbo.
1996cc
Oregon
22 JLUR 392
So do you only need 1 of each part number? The quantity ordered in the post above is confusing.
Upnarms
AZ
2019 JLUR, 2003 TJ X
I just did this mod and I also have the Bolt hood lock. I had to order a second center grille because bolt's J T template told me to cut in the wrong place. It needed to be cut higher than the template said. I don't know if the JT location is correct on the gladiator and maybe the lock mounted higher on the Wrangler but I wouldn't see why it would be differen . Anyway, if you go this route just test fit before cutting the opening. I used a razor blade on the first one but used an xacto knife tip for a soldering iron to cut the second . The hot knife worked great.
Jeep Wrangler JL Where to get Gladiator Grill Inserts? 20200214_083909
Jeep Wrangler JL Where to get Gladiator Grill Inserts? 20200214_083858
1996cc
Oregon
22 JLUR 392
Replaced mine today. Noticed that the trim between the painted grill and the mesh inserts is also replaceable:
Jeep Wrangler JL Where to get Gladiator Grill Inserts? 619C7F4F53E64578A998
I’m guessing that the JT trim pieces would fit better in the areas shown below. And also provide slightly more airflow. If I was doing this again (or if I take my grill off again), I would replace these also. From the front you can’t tell, but it’s pretty obvious on the backside. Hope this helps someone else.
Jeep Wrangler JL Where to get Gladiator Grill Inserts? 95889AC76E7E41B0AEE7
Jeep Wrangler JL Where to get Gladiator Grill Inserts? B3FAED1BD12C40299DEE
I also made my Zauto camera work in the new grill until they come out with a mount to fit the new grill.
Jeep Wrangler JL Where to get Gladiator Grill Inserts? 73E68CB3E8D148289EC6
IronScott
NW Arkansas
2019 JLU Sahara, 1992 Jeep YJ, 2002 Chevy Silverado
How difficult was it to mount the camera? I have the same camera and have wanted to get those inserts but was afraid the camera wouldn’t fit well. Yours looks great.
1996cc
Oregon
22 JLUR 392
It it just took some filing of the top two corners. You can see my file marks if you zoom in. I had to file all the way back on those top two prongs. Just lots of test fitting and checking the screen until I had the right camera angle. The black gorilla tape you see is to hold the camera from spinning to keep the horizontal angle correct. I also used some black silicone to hold the tabs better. Still waiting for Zauto to make the gladiator mounts and then I’ll swap it.
AnnDee4444
'18 JLR 2.0
