Where to get Gladiator Grill Inserts?
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
Ordered. I have been thinking of this and and stumbled upon this thread this morning.
Big Thanks to all of you on this forum. You all make Jeep life easier.
Wapiti
Paul
Eugene, OR
2024 4xe JLURX
I just installed the following components today that I ordered from BAM:
6KM36TZZAARadiator Grille Trim Ring Kit $85.64
6QN22RXFABTexture Grille $12.10
6QN21RXFABTexture Grille $6.02
6QN23RXFABTexture Grille $6.02
It ended up being a lot more of a pain in the ass than I expected as it seems like the trim ring bits don't want to play nice with the JL grille. The insert pieces would have been fine with the JL trim, but the whole point for me was to loose the gray trim in favor of the black. It took some persuading with a rubber mallet, and even then it's still not perfect. I also installed the Mopar winch guard and LEDs. At the end of the day, I'm happy with the look, and the better cooling is a plus
Jeep Wrangler JL Where to get Gladiator Grill Inserts? _4258863
1996cc
Oregon
22 JLUR 392
Could you explain more, preferably with pictures, as to why the trim rings don’t work well with the JL grill?
stino
Justin
Redondo Beach, CA
2018 JLR
BTW, you can buy black grille inserts for the JL from Mopar, if it seems like those will work. I can't find the part number but I have them on my jeep.
Jeep Wrangler JL Where to get Gladiator Grill Inserts? IMG_1892
Wapiti
Paul
Eugene, OR
2024 4xe JLURX
It's all buttoned up, and I didn't take photos. Basically, it seems as if the JT surrounds had a bit more thickness in certain places so I really had to force it together, to the point that I was afraid I was going to break something. Also, the outward upper tab in each headlight opening of my stock grille seemed to be off just enough that the trim never did seat- it was the same with the factory trim ring, and each left a tiny gap that's hard to show in pictures, especially with the satin black. Could be the problem was with my grille, but I tried putting the JL trim back on and it assembled a little easier.
Yep, but oddly the JT trim was like 10 bucks less expensive. I'm pretty cheap, and supposedly the openings are ever so slightly bigger so they work better with the JT inserts. Seemed like a good idea at the time...
WagzDad
Carroll
South Louisiana
I installed the JT grill inserts this morning. It took me about 40 minutes. The Winch was only a minor obstacle putting the assembly back on. The parts from BAM fit with no modification. I didn’t reuse the 4 metal reinforcements for the clips at the bottom and the top clips on the center section were not used either. Th screws and other clips are more than sufficient to keep the center piece in place.
Removal is 6 plastic push locks across the top, 6 metal insertion clips across the bottom and 1 metal insertion clip under each headlight.
Jeep Wrangler JL Where to get Gladiator Grill Inserts? A8DE6C36-B10E-4362-A593-CC074EF0BB82
aquaxp
AZ ->OR
JLU Sahara '20
Anyone with 2.0T engine installed these grill inserts?
Does bigger openings became an issue for multiple additional radiators?
wibornz
Ted
lansing, Mi.
www.instagram.com
The gladiator grill inserts are way easier to clean. They are worth changing over that reason alone.
MILT
Milt
MN
2019 JLU Sahara
Honda technician
I have. I have not seen any positive or negative effects, other than I like the new appearance
Man-of-methods
Paul
2018 Jeep Wrangler JLUR (His) 2018 Jeep Wrangler JLUS (Hers)
Why don’t you guys just leave the inserts off? My brother’s ā€˜17 Recon doesn’t have inserts. That way you get all the air you want with no restrictions.
Jeep Wrangler JL Where to get Gladiator Grill Inserts? F3758688-ABC5-4F4C-B9FD-52C8A764D321
aquaxp
AZ ->OR
JLU Sahara '20
Could you post some photos?
I mostly interested in Gladiator grills because it will make the front camera integration process way more easier. Better airflow will be just a good bonus.
MILT
Milt
MN
2019 JLU Sahara
Honda technician
Jeep Wrangler JL Where to get Gladiator Grill Inserts? 4A7CF991-37E4-45AC-9187-CAE73A1CEEB3
D60
CO
JL
I was thinking this, too. The JT inserts are only going to stop giant bugs - the openings are quite large. Not much different than nothing at all
