TazerJL Feature Requests
SpaceCase
NM
4xe Rubicon
I actually applied for a patent on this 2 years ago before I tried to make it work. Due to how the ABS controller works I was unable to make it happen. I can brake front or rear or both but controlling left and right independently for more than just pulses just wasn’t happening.
I don’t give up easily and still revisit the project from time to time.
I'm curious, did you get the patent?
jeeeeeeep
NV
Not sure if it's possible, but my MINI will roll the windows up / down with the key fob when I press, then press and hold the lock / unlock button on my fob.
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
jludave
The Isle of Long
IT Manager
Can’t be done. The JL window controls are not tied into/integrated with the rest of the vehicle. They are independent of the body control module and the CANBUS. There's no way of "programming" the power window system.
I used to use JSCAN and within it, there are options to enable express down for passenger and rear windows. It doesn’t work.
JeepinJason33
Denver
One question and one request:
After changing gears to 5.13's do I also change the gearing on the 4low or is 4low meaning the 4to1 ration that the transfer case has?
I also purchased the sensor bypass modules because my front sensor would not work correctly after changing out the gears. I understand that this now means I can turn on the lockers at any speed and in 2 hi. Can you make an option to lock these out at higher speeds or in 2 hi?
jludave
The Isle of Long
IT Manager
You didn’t change the transfer case or it’s gearing, so there’s no need to change anything for that.
jludave
The Isle of Long
IT Manager
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
RonAZ
Ron
Scottsdale, Arizona
Here's one for you Joe. When flat towing a JL or JT with LED tail lights the battery can go dead from the third wire on the tail light waking up the Jeep every time a light is activated by the motorhome. Could you do something along the lines of do not wake up if key fob is not present or do not wake up if Jeep is locked??? This would save splicing into the harness with a switch.
JeepinJason33
Denver
Did you use the Cooltech wiring kit? I just finished wiring my JLUR up with that kit. I did not double check to see if it still causes the same problem. Either way, I also installed the RVi battery charger that wires right up to the 6 pin and keeps the battery charged up.
RonAZ
Ron
Scottsdale, Arizona
I plan to install the Cool Tech kit. It would be nice if Joe could do this for everyone that bought his Tazer. I do think that Jeep should do something though. I bought the Mopar kit which causes your battery to be depleted. This should be a defective product unless it includes a software patch to keep this from happening. Perhaps I should contact "Jeep Cares". Haha. All kits will allow this to happen if you don't use a charger or the extra Cool Tech kit.
