TazerJL Feature Requests
rkwfxd
Rich
Whittier
2021 JLR, 2020 Tahoe 4x4, 2006 Tundra, 1990 964
Unemployed
Did you use the Cooltech wiring kit? I just finished wiring my JLUR up with that kit. I did not double check to see if it still causes the same problem. Either way, I also installed the RVi battery charger that wires right up to the 6 pin and keeps the battery charged up.
Same. No issues, yet.
JeepinJason33
Denver
2021 JLUR, 2021 GCL, 1997 TJ, 1983 Chief FSJ
What about a fix for the grinding noise in 4lo? As you can see from the attached link, there are a ton of us with the issue. I found out today that Tazer will fix it if you hold down the traction control key for 5 seconds, however, then you have all the nanny lights lit up on your dash the entire time you are on the trail. Is there a way to just turn it off without lighting up the warning lights on the dash?
https://www.jlwranglerforums.com/fo...ers-side-offroading.60511/page-2#post-1396569
Chocolate Thunder
Jeremy
1. Ability to set the number of times lane change indicator flashes (3-6)
2. Ability to adjust interior lights somewhere between bright enough to signal the ISS and dark enough for a drive by as it is currently
jmccorm
Josh
Tulsa, OK
2021 JLUR
Systems Engineering
My HVAC system would randomly blow warm air like others have reported so after reading here and checking I dropped the glove box and found the connector that goes to the damper control motor and disconnected it and now it does not randomly open letting in warm outside air, apparently it’s by FCA design to do this so fresh air can be brought into the cabin area.
They finally gave in on all the complaints. There's a TSB which covers it, supposed to be a module that gets reprogrammed with the fix.
Chocolate Thunder
Jeremy
Not to derail this thread (@joe@zauto doesn’t seem particularly heavily engaged with it anyway) but I’ve had this issue allegedly repaired 3 times now at the dealership and it still does it. In the future I’ll just press the recirculate button when it happens about once an hour as this is said to correct it.
SwissSteph
Steph
Switzerland
www.swissjeepjl.com
JL Wrangler Rubicon - Hella Yella - 2.2 Diesel
Do you have the number of the TSB? Thank you :like:
jmccorm
Josh
Tulsa, OK
2021 JLUR
Systems Engineering
I believe it is this:
TSB 24-006-19 - HVAC System Update - Intermittent blast of warm air
If you take it in for service, be sure to mention the exact symptom(s) listed in the bulletin, and then go ahead and reference the TSB (or show them a printed copy... preferably of the original, if you can Google it) if you want to make sure that the fix (a flash update) doesn't get overlooked.
Hope this helps, and if it does, let me know, okay?
Abramovich
Arizona
2021 Sport S (Chief) and 2022 Willys XR (Gobi) ord
jmccorm
Josh
Tulsa, OK
2021 JLUR
Systems Engineering
My suggestion: engage @JeepCares with a private message. If the fixes aren't working, they can look to see if you've been applied the right fixes. If so, they'll then Jeep (corporate) will know that they've got some more work to do here if they're going to squash the problem (which they obvious seem inclined to do).
SwissSteph
Steph
Switzerland
www.swissjeepjl.com
If I have an interesting sequel, of course I will publish it here. But my experience is so bad (catastrophic) with Jeep from my country and the dealer that I have no confidence in their work and competence anymore. So I will approach this problem very slowly to be sure to have a correct answer and without, for once, having to do it with the help of a lawyer as for my steering box problem and the famous front axle problem... I am already discouraged
Chocolate Thunder
Jeremy
johnbyron
SF Bay Area
2022 Wrangler 4xe Rubicon
I would love to have a physical "pause" button for the radio.
Sometimes I want to pause a song/podcast so that I can talk to someone in the car without having to scream, but it's not always easy to take one hand off the wheel, look at the screen, and try to tap the small pause button.
The two round buttons between the volume up/down buttons and between the next/previous buttons on the back of the steering wheel would be great candidates.
Additionally, if the front passenger wanted to pause, it would be great to have a second option in the HVAC control, like the Mute, Screen off, or Browse button.
Abramovich
Arizona
These are great ideas. Did you add them to the request list?
