TazerJL Feature Requests
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
As @jludave advised this would change the Tazer completely going to an app, the hardware is all different plus someone has to write the program for the app so if you want an app based program that has lots of the same features as the Tazer I would suggest JSCAN.
They both do lots of the same things but are different in how they handle certain things like disabling ESS and JSCAN is a bit more “Techie” then the Tazer and by that I mean more involved but both are good products.
SilverSurfer
Heinrich
South Africa
2020 JL Rubicon 3.6 8-speed Auto
This would likely add cost and complexity, as you’d need something like Bluetooth added to allow connectivity. I could be wrong, but I don’t see that happening any time soon.
We can control a robot and drone on Mars from earth but we cannot get the Tazer in a Jeep to communicate with a smartphone App, what language does the Tazer speak Klingon?!?
jludave
The Isle of Long
IT Manager
I never said it couldn't be done.
The point I was trying to make is that at the moment, the Tazer is not designed to be used with an app. There's no way of communicating with the device as it doesn't have Bluetooth or WiFi built in. Adding such features would add complexity and cost, as previously mentioned.
If you want an app, use JSCAN with bypass cables and an OBD reader.
SilverSurfer
Heinrich
South Africa
Relax, I was just kidding :)
Black Jeep Convertible
NYC
www.amazon.com
'19 JLU Sport S 2.0T eTorque
Amazon Influencer 😂
Here is a shot in the dark. The bronco is supposed to allow you to turn super tight by braking it locking up the rear inside wheel on a turn, basically dragging that inside wheel through the turn (like a pivot point). Since you can lock up both front wheels for a burn out does that make this functionality possible?
How does Ford get around the solid axle? Open diff?
DanW
Indiana
It would be open at least while executing that maneuver. Honestly, it's a novel idea, but pretty close useless in my years of off roading experience. Even in tight wooded trails. But it makes for good marketing.
LooselyHeldPlans
Brandon
SW Colorado
2020 3.6 JLUR
Several
How would you know without trying it?
DanW
Indiana
Because I've never thought, "Hey, my back end isn't quite getting around that turn as well as I'd like."
To me, it is a solution in search of a problem that doesn't exist, at least in the types of off-roading I've done over the course of 30 years.
There's plenty of things I don't need to try before knowing I don't need it. I've seen some of them on the internet. ;)
NCIC105
Upstate SC
2018 Rubicon
Now wait a minute. You know if it is on the internet, it is TRUE
AZ Hella
Sonoran Desert
JLUR
How about Off road plus in 2 wheel drive? It would be nice to have the aggressive throttle mapping for the street.
tubaom
Tom
Colorado Springs, CO
05 Diesel KJ, 20 Diesel JLUR (ordered), 13 Diesel GMC Dually
Before I forget... The ability to keep the rear tailgate locked even if the unlock button is pressed. Seems like jeep forgot that the cubbie under the tailgate isn't secure if you can simply unlock all the doors with the button on the front doors.
LooselyHeldPlans
Brandon
SW Colorado
2020 3.6 JLUR
Several
Here's an idea... Could we up and down shift with the little circular buttons behind the steering wheel? If that could be added, I bet it would drive a ton of new customers.
@joe@zauto
Is this possible? Controlling the trans shifting via the steering wheel is something that is really missing from the JL while engine breaking in the mountains.
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
I would use it every day commuting in my Gladiator ?
joe@zauto
Commack, NY
2018 wrangler rubicon unlimited
I actually applied for a patent on this 2 years ago before I tried to make it work. Due to how the ABS controller works I was unable to make it happen. I can brake front or rear or both but controlling left and right independently for more than just pulses just wasn’t happening.
I don’t give up easily and still revisit the project from time to time.
