Tazer (Programmer) for the JL
Status
Not open for further replies.
Wrangler-NS
Guy
Halifax, NS, Canada
2018 JLU Sport S
Did you go to live menu, where it says “Winch: x” and set the RPM to use?
The 11.1.2 firmware had a problem where coming off a previous version would set the RPM to some negative value, and wasn’t able to be changed back in range. 11.1.4 fixed that so you can change it to 1300-2000. If you didn’t change it, it’s probably still out of range.
Yes. Mine is set to 2000.
joe@zauto
Commack, NY
2018 wrangler rubicon unlimited
Should work then. Need to have your foot off the gas and brake. Then hit the two buttons (right arrow and cancel) and it should say “Winch on” and RPMs should slowly rise.
DanW
Indiana
Joe, do you have to unmarry the Tazer JL to update it, or can you just remove it, update, then plug back in? I'm getting ready to update mine.
Thanks!
Trav.city
Rich
Michigan
2018 Wrangler Unlimited JL Rubicon
Sales Manager
Thanks!
Courious as well. I have the mini, I think I can just plug into it without removing? Thanks
joe@zauto
Commack, NY
Thanks!
For 11.1.2 to 11.1.4 nothing I changed requires an unmarry/marry as all the saved data structure remained the same.
If you’re updating with Windows just go for it. You can even use a laptop in the Jeep without needing to unplug it. If you’re using a Mac I’d prefer if you unmarry as the Mac’s sometimes don’t play as nice and I’ve seen some updates cause an issue with saved data.
DanW
Indiana
I'll be using windows, but I'll have to check to see what previous version I have. i think mine is pre 11.1.2. I'll be using Windows, but it still looks like I'll have to unmarry it. That's ok, though. No biggie. Thanks!
BostonBilly
Billy
Mass
2015 JKU
I just updated and will marry it back in once I get my Jeep back from the dealer.
islandtees
gary
florida
2025 Final Edition 392
I updated and noticed a few things. Start stop better, but it still misses. Sway bar disconnect doesn't always work in 2 wheel drive. Same for locking axles.
Trav.city
Rich
Michigan
Sales Manager
Just updated my mini. Very easy. Haven’t demoed anything yet though. Thanks for continuing to improve this.
ABar112
Adam
Griffin, Ga
2018 JLU Rubicon 2016 Hyundai Veloster Turbo
Lot of pages to read through, so sorry if this has been asked already. joe@zauto, have you been able to or attempt to try to get off road pages to load on an 8.4 radio that was installed on a Jeep that had either a 5" or a 7" radio originally? I swapped my 7 to an 8.4 and did uconnects newest update that included the ORP, and other updates, but it doesn't load that app of course (all other functions that should do) and i assume it's because the BCM doesn't tell the radio to display the app or send the info to it? I also installed the wifi antenna and i get wifi so that what has me wondering if its a programming thing or if some other wires should be ran to the radio from the cluster to display the info?
If its a programming thing, do you think the Tazer could handle it, like the other OEM swaps/upgrades?
Wrangler-NS
Guy
Halifax, NS, Canada
2018 JLU Sport S
Got it. I had to change the value of the RPM and then it worked.
NCIC105
Upstate SC
2018 Rubicon
Winch mode works perfectly for me as well as other functions...Hats off to your and your crew for a great product...
Oh and the Wench mode works good also...Bahahahah
SleepEatJeepRepeat
Michael
Newport Beach, Ca
2021 JLUR, 2020 Audi Q7
Looking at Jeep stuff all day
Sorry if this was already answered, but has anyone put this on the new 2020 2.0 turbo engine without the mild hybrid, i went to order and noticed it ask you to specify the motor, and the new 2020 version of the turbo is not listed.. just want to make sure it works fine before ordering.
OldGuyNewJeep
Don
CT
If I’m not mistaken, he only asks engine type to build a demographic. The unit and firmware is the same for 2.0 and 3.6. Also, it’s a programmer not a tuner so should be no issue.
JLUSoCal
IT
Me too on the winch mode I reported not working. It was set to -1 (does that mean the engine runs 1 rpm backwards haha).
It works perfectly - thanks Joe for the info.
Really like the sway disconnect and maybe some are not getting to a stop to make it disengage?
Status
