Regret 37s?
RUSTYS
Rusty
PA
JLUR
Guitar slinger
4:10 Gears and 37’s will leave much to be desired.
Sorry I ran 37s for a year and it was great. Ran 38s for 6 months with no problem before I regeared to 5:13s. By your response I would say you don't have a Rubicon and you've never had 37s on one. Thanks.
Mikester86
2022 JLR
I own a 2020 JLUR still in stock form. I know there is proper gearing for different tire sizes. And 4:10 Gears and 37’s although ok, is not ideal. That’s all I mean.
ChadTx
Chad
Central Texas
Looking to order 2021 Wrangler Rubicon 2 door
JLUR with Mopar lift, Mopar Slotted Off-road wheels (+12mm offset), 37" KO2s. No regear needed (with automatic), No rubbing.
I like those wheels on a billet silver rubicon. Can u show me more pictures of ur Jeep with those wheels?
BobK
Bob
Parker, TX
2018 JL Rubicon Unlimited
Semi-Retired
I was the second poster to this original thread in 2018. After reading here and doing my research, I installed 37" BFG KO2's on KMD Rockstar wheels along with a Mopar 2" inch lift kit. I also replaced the front and read bumpers and when doing so, I removed the small section at the bottom rear of the back wheel wells that connected to the rear bumper.
I've never had a single rubbing issue and I wouldn't trade my 37's for anything, except maybe 40's (who says size doesn't matter). I've had so many positive comments about my Jeep on 37's and I've also driven for twelve hours straight at highways speeds (+ 85 mph in 8th gear).
I did install a set of Rock slide Engineering drop down step/sliders to deal with the increased entry height for my wife and granddaughter and frankly it helps me too. I love the look and driving feel of the JLUR on 37's.
Jeep Wrangler JL Regret 37s? IMG_0352
By the way, the spare is being remounted this weekend using the Mopar hinge reinforcement kit (already owned it from original purchase) and the Teraflex HD spare tire carrier kit, along with the Artec license plate mounting kit with the Off Road Only license plate lighting kit. More pics after the install.
conFUcius
Stephen
North Carolina
2024 Supra MKV 3.0, 2024 392 JLUR
Medical Affairs
Did you re-gear and, if so, what ratio?
BobK
Bob
Parker, TX
Semi-Retired
Nope, no re-gearing necessary. I can still see the Jeep in 8th gear on the highway, so I personally don't see the need. There are many voices on the forum that will disagree but I have zero performance issues with 37's and a two inch Mopar lift.
SleepEatJeepRepeat
Newport Beach, Ca
2021 JLUR, 2020 Audi Q7
Looking at Jeep stuff all day
So I have 35s now ridge grapplers ...
What I don’t like
1) always look at them from the side and think they need to be a little taller
2) they are E rated and very stiff on road, and don’t flex that well deflated (Chirping on rocks too often)
3) they weight 75lbs each and while it still is nice to drive I feel the weight of the tires during acceleration and braking for sure
solution:
ko2 37” tires
1) taller by 1.74”
2) lighter by 5.5lbs
3) d ply so softer, should flex well aired down
Results;
1) will gain ground clearance on axles and break over, and will achieve the look I want
2) lighter tire should accelerate and brake better
3) d ply should give better on-road ride, and better rock grip when deflated
The ridge grapplers look awesome and are very quite though after 5k miles they started getting louder and have a light hum now. The ko2 is a more refined tires that is also well regarded off-road.
so I want to know is my assumption that a lighter tire even if taller will accelerate and brake better.. or does the height of 1.74” taller make a bigger difference rotaionally and will matter more than the weight? My main goal is to achieve better driving dynamics.
also I should mention my 4banger turbo got bought back and this new set up will in the v6 etorque that gets delivered in a few weeks . I will also be ditching a spacer lift for a full spring lift with lower control arms.
JWAustinVTX
Jason
2019 Sahara Unlimited
Does anyone here have the mopar lift with 35’s and park in the garage at home? I’m thinking it’ll fit but was wondering if anyone knows for sure.
Should not be an issue with several inches to spare in a standard garage.
Sgt Beavis
Rick and Miyako
Wrangler JL Unlimited Sport S
The Man, The Myth, The Legend. In my own mind.
This is a great thread with lots of fantastic info. Y’all. have pushed me over the edge for getting 37s. But I do have a couple basic questions.
I’m going to go with a Rock Krawler 2.5” Max Travel “No limits” lift. I just need to decide on shocks (not decided on RTTs yet). But I’m also planning to use the base Rubicon 17x7.5” wheels. Do you folks know if I need to use spacers or will this work just fine with no rubbing? Please note that I absolutely off road my vehicles and I plan to be in max flex situations.
conFUcius
Stephen
North Carolina
Medical Affairs
With regards to your shocks, I went with RK’s RRD shocks (got the Adventure Series 2.5” Stage 1 kit). Figured I’d keep the springs mated with the same manufacturer’s shocks.
