Regear or Not
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I gave you first hand experience from a 5.13s on 37s.
Nothing I have said misled anyone.
The 2.0 and the 3.6 are different.
The 8spd and the manual are different.
And god forbid the diesel guys read this, it'll be anarchy.
I drive a diesel JL....
  • Haha
Reactions: JT1
JT1
Broken Arrow, OK
2021 Willys Gladiator
Bull shit. Well into boost by 1900rpm? Nope. The 3.6L makes more torque than the 2.0t until about 2200rpm because it's not into boost yet. And who cares if they are both gutless below 2300 rpm? You don't want/ need to be at peak torque or boost when cruising around at low loads which is the whole point of having 2 overdrives. Some people act like the thing takes more than a fraction of a second to downshift and get into the power/ boost.
Also found this chart posted on this forum too. Shows that at 2000 rpm the 2.0 is making 40-50 more ft-pounds than the 3.6. The TQ cross over happens around 1500rpm when the boost starts building.
Jeep Wrangler JL Regear or Not 1752264608837-w6
Zandcwhite
Zach
Patterson, ca
2019 jlur
I promise you and @grimmjeeper can attest, these new 3.6s do not do SHIT until right after 1900rpm.
I've watched 2.0s on 4.10s and 35s spin both tires on pavement without launching it on the converter. The 3.6 won't.
The dyno chart doesn't lie, neither engine makes shit for power below 2k rpms. The 2.0t makes less than the 3.6L below 2200 rpm period. But hammer the throttle on either and you're well beyond that nearly instantly. The 3.6L needs to get to 4k plus for peak torque and 6k plus for peak horsepower which is the diffrence you're feeling. Below 2200 rpm both are gutless. Beyond that and into the boost the 2.0t comes and strong and fast. The 3.6Ls torque output just remains gutless and no amount of gearing is going to fix that. Unless of course you cruise around at 4k+ rpms, but that's dumb.
TyRoosevelt
Tyler
Colorado Springs
2024 Jeep JL
Not when I'm talking about the manual transmissions. Do try and follow along.
What the hell are you talking about? You didnt specify manual transmissions at first and the JK and JLs are still geared differently even with the manuals. Do you know what you are even talking about? Any change, no matter how small, will change the impact of a regear.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
JT1
Broken Arrow, OK
So you didn't look at the chart I posted?
That clearly shows at 2000rpm that the 2.0 is making more HP and TQ than the 3.6?
Jeep Wrangler JL Regear or Not 1752265145800-66
That pull shows 1600rpm to 2200rpm. Yellow is 2.0TQ, orange is 3.6TQ. gray is 2.0HP, light blue is 3.6.
The boosted one is ahead at 1600rpm and not by a small margin.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Any chart that smooth isn't a real dyno chart period. The perfectly flat m235 line is even more comical. I'll stick with legitimate dyno charts from reputable sources. Go ahead and put a boost gauge on the 2.0t and see for yourself if it's well into boost below 2k rpms. It's not and I know that for a fact as our 2019 had a gauge on it.
Zandcwhite
Zach
Patterson, ca
2019 jlur
It does if you find one that starts the run off the throttle above idle. Especially with a turbo.
To get the most accurate dyno run you should be in 6th gear (1-1) I'm pretty sure you can't even get it to manually shift into 6th at idle?
TyRoosevelt
Tyler
Colorado Springs
2024 Jeep JL
It really isn't. There wasn't any major change to the 3.6 besides incremental upgrades and fixes.
I'm sorry I assumed you understood that.
JK
4.46:1
2.61:1
1.72:1
1.25:1
1.00:1
.84:1
JL
5.13:1
2.61:1
1.53:1
1.00:1
.81:1
.74
Just to help you out. But you are right. No major changes
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Not like you could back in the day.
I don't know how they lock in any gear with an automatic on a dyno run anymore. The computer will downshift unless you can force it somehow. And if you can do that you should be able to do it at any RPM.
Manuals are still easy. Pick the 1:1 gear and floor it.
Zandcwhite
Zach
Patterson, ca
2019 jlur
I have a 6spd gladiator on 37s and 5.13s. The 3.6 in the JLs was tuned by incompetent space monkeys.
The 8spd covers up the <2000 rpm power deficit with more gears and a torque converter.
I wheel with a 2.0 rubi on 38s and 4.88s and thats a really nice combo all the way around.
I probably would have done 4.56s in mine if I had a rubi. The 4:1 transfer case and 4.56s is similar to the 2.72:1 and 5.13s crawl ratio wise. 4.56s in 5th gear is the same final drive ratio as 5.13s in 6th.
So you're telling us that 75-1 is a similar crawl ratio to 95.6-1? Deeper tcase gears make a much bigger difference in crawl ratio than axle gears.
Beach Nut
Al
Fredericksburg VA
2020 JLU Sahara
There isn't much difference in rpm in top gear from a 33 and 4.10 to a 37 with 4.56
I’ve got 3.45 gears in my 3.6 JL, spinning 35s…hardly ever see 8th gear…only downhill on a highway! Most shops recommend 4.56 gears for 35s…4.88 for 37s. Just what I’ve been told by several shops.
Beach Nut
Al
Fredericksburg VA
2020 JLU Sahara
Yeah. It doesn't hurt to do things in stages. You learn the most off road by having a Jeep closer to stock. I got started with an XJ on 30" tires and no lockers. I really had to develop my driving skills to keep up. That has served me well.
Had an XJ on 30s also. Great time with it!
Jeep Wrangler JL Regear or Not IMG_8112
Vicrider
2020 Wrangler Sport
I have a gladiator on 35's with 3.73 it sees 8th on flat ground and gets an average 19mpg, it's also just fine offroad, now im not pounding it on a vertical rock face but it's climbed 38degrees without much trouble. I think it would be perfect with 4.10. We also have a jlu xr with 4.56 on 37's and it's fantastic, I wouldn't even consider changing them. Also have a 2 door jl on 33's with stock 3.45's motor is a 2.0 turbo. It climbs grades in 8th. Sometimes I just dont understand where some think that jlu needs 5.13's on 37's.
