Rear steer
JINO
Jino
Socal
2021 jlurd
I googled, but couldn't find anything useful.
How much would it cost to add rear steer to the JLs?
And cons to having rear steer for a mostly daily driven, weekend warrior jeep? I do moderate to near hardcore crawling.
Zandcwhite
Zach
Patterson, ca
2019 jlur
I'd say to do it right your looking at $20k by the time you buy an entire steer axle and the hydraulic steering components and pump to make it work. Not to mention being that you're running a front axle in reverse all the time you'd want at least a Dana 60 as the gears are weaker running them that way. Way more trouble than it's worth, especially in a mostly daily driver. If you want a buggy....buy/ build a buggy.
Roky
Roky
Even if it was easy and inexpensive, I don’t think I’d do it, I don’t need any help getting myself in a pickle Offroad…. But then again, getting out of it is where a lot of the fun is, so I guess I’m glad it’s expensive and not worth it….🤣
Terrymo
Terry
2023 JLURXR 3.6 ET
Think how much easier parallel parking would be…winning!
roaniecowpony
Retired Engineer
Adding that level of system complexity to a DD is just asking for many days of finding an alternative to get to work. When you look at rear steer production vehicles like the GM pickups that had it ~20 years ago, you see that they had safety features to prevent uncontrolled movement at high speeds, which would be catastrophic. These features are designed to be "fail safe" because of the consequences of failing "hard over". A true crawler is going so slow that a hard over failure isn't life threatening.
It's impractical and for most it's irresponsible for a DIY highway vehicle.
Roky
Roky
This would come in handy as long as it tucked up enough not to decrease departure angle.…🤣
Jeep Wrangler JL Rear steer IMG_0641
Terrymo
Terry
2023 JLURXR 3.6 ET
I’m waiting for Jeep to partner with DARPA especially for the suspension system
