Steer like Xterra
KleetusVanDamme
Marty
Piedmont, North Carolina
2023 Wrangler Unlimited JL Earl “Lt. Dan”
Hello out there! My wife has a 2023 JLU with a 2” lift and MT 35” tires. I drive a 2005 stock Nissan Xterra as my DD.
Wife uses her Jeep as her DD, and when we were out and about yesterday I noticed how she has to really work with the jeep while driving on pavement (much less than when she drove the Xterra).
My question is: Are / do jeeps hand and feel differently than other vehicles?
If so, are there any mods / parts that I can add to make the drive feel safer for her?
Thanks in advance, Marty
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
A vehicle with a solid front axle (focused on rock crawling prowess) typically won't drive on road as well as one with an independent front suspension (not focused on rock crawling prowess). It's a fundamental decision/compromise that means her Jeep won't drive as well on road as it could if it was less off road capable.
The challenging part is to figure out if hers is actually driving as expected or if there's really something wrong with it.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Can you describe "really work"? Are you talking about one fingering the wheel on the highway on straight stretches? Steering effort when parking?
autotragic
the cornbelt
'21 JLR 6MT
With a 2-in lift I bet it could use some longer front lower control arms for increased caster.
Apexcars
North Texas
2020 RAM 1500
1. Yes, Jeeps drive differently. They are solid axle vehicles, very few vehicles on the road now are solid axle. You mostly notice it over bumps and uneven surfaces. Prior Jeeps also had pretty loose steering which made it worse. Then if you start going taler than a stock sport, the front lower control arms are too short and mess up the camber which makes the vehicle not hold a line as well especially on bumps and uneven surfaces.
2. Correct length LCAs and upgraded shocks help a ton with those issues. These are not expensive fixes either. Since doing both of those things my Jeep drives really well, probably not that much different than the Xterra really.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
This ^^
Also keep in mind that the Xterra has independent front suspension. It is completely different than what is on a Wrangler. You can make the solid axle Wrangler better with the above suggestion, getting the camber in the 6 degree range, but it will never drive and handle like an IFS vehicle.
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
Put the 35s on the Xterra and I bet it’ll feel the same.
  • Like
Reactions: RZ.
Zandcwhite
Zach
Patterson, ca
2019 jlur
1. Tire pressure. Anywhere near the 37psi on the door placard makes the jeep twitchy. For 35s I'd go 32 psi tops
2. As others have said caster. Jeep says 4⁰ is within spec... that doesn't mean good. 6⁰ causes much less wandering.
3. It is still a solid axle so it wont drive like an xterra
dsgrey
Kevin
2019 JLU
Solid front axle is a plus for some of us. The spouse has only driven my Wrangler once in 5+ years because it doesn't drive like her Honda. Funny how she doesn't complain when I have the top down or we take the Wrangler on long trips because it can hold all the stuff, but she isn't driving.
Old Dogger
Bill
Cave Creek Arizona
Your Wrangler has a solid axle, plus electronic steering assist. So yes, it will feel different on highway. Experiment with your tire pressure, to see if that helps. Start with 30 psi cold in the mornings, and then work your way up to 35 psi. If that doesn't resolve your issue, then take it to a front end alignment shop. Have them set the Caster to a positive 6 degrees. If you don't already have these, then they will have to install adjustable lower control arms.
RZ.
Doug
Pensacola, FL
2018 3.6 Sport S
Blueprints & Tarot
I never made it up to 35's with this ol' beater -here she is on 33's - but it's true ... the better they are offroad, the worse on.
Jeep Wrangler JL Steer like Xterra Fronterra
Ratbert
PNW
Software Engineer
I'm pretty sure the max you can put on an Xterra (without replacing most of the suspension) is 33s. Even then it'll ride better than a Wrangler on everything but rocks due it having an IFS.
KleetusVanDamme
Marty
Well I guess I have done all I can then. The 2” lift I put in came with LCAs (Mammoth 2-Inch Suspension Lift Kit with Shocks). I will play with the air pressures. I also saw a YouTube clip regarding the adjustable steering stabilizer (specifically this one: Falcon Shocks Nexus EF 2.2 Fast Adjust Steering Stabilizer), but again, I don’t have a clue if this will help much, or be a $400 crapshoot.
Thanks from the bottom of my heart for all the excellent suggestions and support.
Regards
  • Like
Reactions: RZ.
Ecorubi
Israel
Kansas
2021 Rubicon Ecodiesel
I 2nd the idea of playing with the tire pressure and maybe consider an aggressive (or not) AT instead of mts for the next set of rubber
GATORB8
CLT NC
Regards
What specifically is your steering concern?
