Rear Bumper Integrated LED Reverse Lights
tatarin
Russ
Bloomingdale, IL
2019 MOAB Mojito Sky One-Touch, 2015 Lexus RX350F-sport, 2005 Camry SE
I'd much rather have them all white for the extra brightness in reverse. My brake lights are plenty bright already.
Agreed
tatarin
Russ
Bloomingdale, IL
is there an ETA on these?
ORACLElights
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
We will release more details and an ETA when available! Thanks for the excitement :like:
RRCastle
Peoria, IL
2018 JULR, plus too many others...!
Anxiously awaiting! I'll hold off on making my own - despite having already purchased all of the necessary parts!
ORACLElights
ORACLElights
Metairie, LA
We appreciate the continued enthusiasm! With the final adjustments now made we are going to be building prototype parts for beta testing before opening molds. There is a possibility of doing a group buy if there is interest. Just want to be sure we explain that manufacturing takes a while, tooling, processing, assembly, etc all while following our Control Plan and taking the correct QC steps along the way will take some time.
A few things to note:
1) We were able to design to install without having to drill any holes. Even though the bumper was not designed to have a cable outlet we were able to use an existing port for the cable to exit.
2) Power can be pulled from the reverse lights or aux switch not both (unless you have some wiring knowledge and use diodes). To get power from the reverse light the cable whip can easily be routed to the tail lamp on either side. The cable routing is very simple. The + and - wires will need to be tapped to get power from the factory tail light.
3) Tools needed for the installation: 7mm socket with swivel adapter.
4) Anticipated installation time: Less than 1 Hour.
Any other questions let us know!
Fire Burns
Fire
CA
2018 JLUR 3.6; 2006 Chrysler 300c SRT-8
Again, would prefer a customer selectable installation regarding used as an auxiliary light (tied to a switch) or a dedicated backup light (automatically comes on when backing up)
Thanks!
Monkeynono
Southern New Jersey
2020 JLUR
Would a relay not work to be able to use both (aux and reverse)
Nutmeg
Connecticut
2019 Wrangler
Like the idea, interested to see the final product.
As an FYI this has worked for me. My JL has the auxiliary switches / towing package. When I wired my current auxiliary backup light I used a roadmaster diode.
https://www.amazon.com/Roadmaster-7...HSJ5V0Z3HES&psc=1&refRID=F6Q1MTM8FHSJ5V0Z3HES
One input was tied to an auxiliary switch output and the other input was tied into the backup light feed of the tow package wiring. This gives me automatic rear auxiliary lighting powered off the independently fused tow wiring and the ability to activate on demand from the auxiliary switch.
Abramovich
Arizona
2021 Sport S (Chief) and 2022 Willys XR (Gobi) ord
Yes, that is perfect for using these lights as both backup and using an AUX switch. Thank you!
klhjeep2018
Kevin
Harpers Ferry, WV
2018 Rubicon JL
Sales manager
Sounds good, keep us posted for updates.
I'm sure everyone on this post would be very interested in a group buy.
Thanks For The Information
