Post Metalcloak LCA install
Rmag24
Robert
NJ
2019 Wrangler JLU
I had the MetalCloak lower control arms installed today at an alignment shop. So far it doesn’t seem like it’s really changed any of the drifting wander loose steering issues I was having. It did however eliminate the vibrations I was getting at around 50-60 MPH. I’m thinking the caster is is to low as it’s listed at being 4 degrees. Any suggestions ?
Jeep Wrangler JL Post Metalcloak LCA install 3A52A997-E8C2-46C8-BB35-357A8791B4D0
Jeep Wrangler JL Post Metalcloak LCA install 22B83ADD-20C2-4B3A-A74A-BC796D59BD08
Jeep Wrangler JL Post Metalcloak LCA install 30BE7EF6-1CB2-4F10-B99B-538468E256AF
JeepJLU402
Nebraska
2019 Wrangler JLU Sport S - V6 8AT - 30/44
Isn’t the jam nut supposed to be on the frame side? And why did they zip tie the brake line bracket to the control arm? I don’t think those are installed per Metalcloak instructions.
Buddy Lee
Victor
San Martin, California
2021 JL Rubicon Unlimited
First of all your Metalcloak lower control arms are installed backwards. The adjustment bolt goes towards the center of the jeep and the fixed bushing goes into the axle. You need to have the shop swap the arm locations and rotate them into the right orientation. Second you need to add more caster. 6 degrees seems to be the sweet spot between improving the JL's driving characteristics and not exacerbating pinion angles (can create vibrations) in the front end.
nsfw_andy
2022 Hydro Blue JLUR Ecodiesel
Front driveshaft doesn't spin in 2HI because of the FAD so you shouldn't get any vibes unless you are have the full time 4x4 setup.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Which is why I run mid 7⁰s, it drives better and I don't get any vibes even in 4hi at 60mph+ out in the desert.
somedude922
McFrisco
2021 JLUR, Previous: 1984 CJ7, 1979 CJ7
Ouch. They are installed backwards. They are side specific too. 4 degrees is way to low, aim for 6 degrees. Paint mark those control arm bolts...I bet they are not torqued to spec, and may back off.
Apparently the installer didn't read the instructions.
Rmag24
Robert
NJ
2019 Wrangler JLU
Appreciate everyone’s help. I returned Monday morning and explained that they are backwards and the manager blamed the fact that there were no instructions in the box. He also tried to say that it doesn’t matter which direction they are installed. After some discussion he agreed to swap them. I now have to find another alignment shop to check the specs again as I suspect they didn’t increase the caster like I asked.
I do feel the steering has tightened up but noticed that when shifting the wheel from center the right side has more play in it then the left.
Should I shoot for another alignment first or buy anything else? I’m considering some sort of HD steering setup with adjustable track bars.
Thanks
Hucke_250
Ohio
2018 Unlimited Sport
Thanks
If you don’t have a torque wrench I’d take it to another shop to have the caster and alignment dialed in. I’d also have them go over the steering components with a torque wrench. Make sure they provide you with an alignment printout.
